Latest: lio94
Overall: 17181
Online Now [85]:
Visitors: 84
Today: 8351
Total: 141198445
Forums › The Car › 206 Talk › Removing seat cloth/cover?
adsayer
PostPosted: Sat Jul 07, 2012 2:55 pm Up
Hi all,
Was so impressed with the GF's 206 I decided to get myself one.
Largely it's in good nick apart from a few bits and bob's which I've been sorting out today.
One problem, the driver seat base cover, the stitching has come loose showing the foam. I under that you can separate the seat into its constituent parts but have no idea how Razz
Ideally I'd like to get the base off, so I can remove the cloth and repair it. Any suggestions how how to achieve this would be brill!
Thanks,
Ads
Dodgernator
PostPosted: Sat Jul 07, 2012 3:49 pm Up
Just undo the 4 bolts holding the seat in place and remove from car. This method is makes it much easier to tackle. Then just turn upside down and you should be able to see what connects to where. This problem is common with the cloth seats (caused by heavy peeps). I tried the stitching myself but it just kept ripping again.
My advice is to switch to a set of leathers as they're better made.
adsayer
PostPosted: Sat Jul 07, 2012 3:50 pm Up
Honestly, I did do a search. However I came across this in the How-To section, which covers the 180 model but might be applicable to the lesser models - which I'll try tomorrow.
www.206info.co.uk/Foru...27348.html
just case someone else comes across this thread...
ads
Cars: 03 206 Look 1.4 HDi & 02 206 Style 1.4 HDi
