Posted: Sun Jul 08, 2012 10:29 am |
How difficult is it to replace a strut bearing, front off side? Is there a how to?
Posted: Sun Jul 08, 2012 10:39 am |
I think you need spring compressors so not that easy, gonna get mine replaced when my new rear axle is fitted as they have been making noise for ages
| You never really learn to swear until you learn to drive | |
Posted: Sun Jul 08, 2012 10:50 am |
if you've not done it before its a pain in the ar*e. If you are likely to be replacing more parts, thus repeating the job, I suggest you learn and save yourself a load of moola
You need to remove the strut from the car for a start.
Posted: Sun Jul 08, 2012 4:36 pm |
Pain in the a**e! Not hard but quite a few bits to disturb / remove and always a bugger reconnecting that lower wishbone.
Also very dangerous if you aren't used to using spring compressors.
Buy yourself a Haynes manual. It isn't the answer to everything but it always gives a clear idea of just how easy or hard a job is. Use the manual but ask what special tips others know here.
