Latest: airmastertapes
Overall: 17133
Online Now [427]:
Visitors: 426
Today: 54218
Total: 106587831
Forums › The Car › 206 Problems › Developed some creaks!
Andrew
PostPosted: Sun Jul 08, 2012 3:25 pm Up
Hi
The way my driveway and pavement slope there is an apex, so when I turn on or off my drive I hear a creaking noise from the sides of my car. I can see that the retaining pin on my check straps are going, but not sure if that could be the cause.
Also I get a slight knock from time to time when the engine load changes (let on/off the loud pedal) come from the engine bay. I spotted a thread earlier where a 180 had a crack in the metal near the RH mount so I'm hoping its not that.
Does anyone have any ideas as to what could be causing these noises in my case?
My 206 thread
www.detailedbyandrew.com
adsayer
PostPosted: Sun Jul 08, 2012 4:24 pm Up
With the creaking I decided to change the wishbones, which solved the problem for me.
Cars: 03 206 Look 1.4 HDi & 02 206 Style 1.4 HDi
Creak - jack the front and have good look for play in the front swivel joint on the end of the wishbone. When these wear they can make a lot of noise.
Creak - rear axle bearings?
Knock could be either cracked or worn engine mount, driveshaft or exhast hitting bodywork.
Andrew
PostPosted: Sun Jul 08, 2012 4:48 pm Up
Thanks for replies
Come to think, my tail pipe sits too close to the bumper (melted paint on track day), I could do with some longer exhaust rubbers
I'll get checking on those again, thank you. I think my suspension needs an overhaul!
My 206 thread
