Latest: lio94
Overall: 17181
Online Now [210]:
Visitors: 209
Today: 4388
Total: 141087878
Forums › The Car › 206 Problems › Tight as a....
Tight as a....
TJsmith
PostPosted: Fri Jul 13, 2012 11:11 am Up
Just bought some Bosch super 4s for the pug, went to take the old plugs out, and there all as tight as a nun apart from one? The engine was still slightly warm when I attempted it so thought this might have been the problem, expansion and all...
Any suggestions? I'm gunna try again first thing in the morning.
Also... Is there a oem tool for the 206? Cause they ain't half awkward to get to on the little 1.1 mower
Cheers
PostPosted: Fri Jul 13, 2012 11:12 am Up
The spark plugs are awkward to remove? Seriously??
TJsmith
PostPosted: Fri Jul 13, 2012 11:20 am Up
Not really awkward to get too, just can't get the right leverage with the spark plug remover I've got....
You must be using a tiny ratchet?
TJsmith
PostPosted: Fri Jul 13, 2012 11:24 am Up
Here's the tool I'm using
Wouldn't say I'm the weakest guy either, they are solid, won't budge at all
PostPosted: Fri Jul 13, 2012 11:29 am Up
Spark plug remover + a normal ratchet will get them off easy, you just can't get leverage with that tool never used one myself doesn't look that practical
TJsmith
PostPosted: Fri Jul 13, 2012 11:32 am Up
Yeah, it is a tad awkward, I do have a spark plug socket somewhere so will give it a go with that when the engine cool
PostPosted: Fri Jul 13, 2012 11:37 am Up
If you can get a pipe on the end or even mole grips to get a bit more leverage it would probably work
PostPosted: Fri Jul 13, 2012 11:38 am Up
socket and extension bar will do the job.
PostPosted: Fri Jul 13, 2012 11:40 am Up
8 valve TU spark plugs must be about the easiest ones to do there is, 10 minute job tops.
PostPosted: Fri Jul 13, 2012 11:41 am Up
Angle joint essential and so is torque-wrench.
Yep, I'm a nerd big-style.
TJsmith
PostPosted: Fri Jul 13, 2012 11:45 am Up
Alright I know changing the spark plugs are easy, I'm just struggling to remove them cause some knob'ed has over tightened them.
I'll give your suggestions a go, cheers guys
PostPosted: Fri Jul 13, 2012 11:46 am Up
TJsmith wrote:
Alright I know changing the spark plugs are easy, I'm just struggling to remove them cause some knob'ed has over tightened them.I'll give your suggestions a go, cheers guys
PostPosted: Fri Jul 13, 2012 11:49 am Up
Why do I get the feeling the threads in the cylinder head are going to be damaged Whistle...
I havent used a torque wrench on spark plugs in years BUT the job I do everyday you can just feel when something is correctly tightened OR a thread is damaged.
PostPosted: Fri Jul 13, 2012 11:52 am Up
Wonder if we have some cross-threaded action on the cards...??
