Latest: Beduff1977
Overall: 17134
Online Now [645]:
Visitors: 645
Today: 23683
Total: 107336069
Forums › The Car › 206 Talk › Rear Wing Guard
Rear Wing Guard
PostPosted: Fri Jul 13, 2012 12:39 pm Up
what do you think? chavyyyyyyyyyy Razz
PostPosted: Fri Jul 13, 2012 12:46 pm Up
Seen worse on here Whistle...
PostPosted: Fri Jul 13, 2012 12:50 pm Up
Razz
for that kind of price i can't really complain Razz
only discover i am running out of rivet Sad
got hundreds of other size but not the one i need Sad Sad Sad
swaynie
PostPosted: Fri Jul 13, 2012 12:56 pm Up
wow Shocked erm Confused and why would you want to lol its gash
If your offended by my posts call\r\n0800 I dont care Wink
PostPosted: Fri Jul 13, 2012 12:57 pm Up
because it is so gay
PostPosted: Fri Jul 13, 2012 12:58 pm Up
Best answer ever...
parkesie
PostPosted: Sat Jul 14, 2012 1:13 am Up
Rivets ? Wing guard? Wing ruined by holes and rust by the end of winter.
Signature p**s
PostPosted: Sat Jul 14, 2012 2:10 am Up
Is that green paint? I'd encourage stone chips if it is!
DeadEyePaul
PostPosted: Sat Jul 14, 2012 2:22 am Up
WHY?! you going to go on a gravel track and do handbrake turns?
PostPosted: Sat Jul 14, 2012 2:58 am Up
He has just got his race licence. Wink
PostPosted: Sat Jul 14, 2012 3:01 am Up
ACF-50 solved the problem
there is no way i would use tiger seal to put it on
PostPosted: Sat Jul 14, 2012 3:03 am Up
i think i will start from auto-cross if cash permitted Laughing
parkesie
PostPosted: Sat Jul 14, 2012 3:39 am Up
Ahh your going to be thrashing the nuts off it makes sense now. Would of just stuck it on without rivets myself. Lets see some pics of it covered in crud and going alsorts of sideways Smile
Signature p**s
Barking
PostPosted: Sat Jul 14, 2012 3:43 am Up
sticky-back plastic FTW
carbon-fibre s/a sheet would've looked better IMO John Smile
I got a dig bick.
You that read wrong.
You read that wrong too.
PostPosted: Sat Jul 14, 2012 4:58 am Up
i though about that before.
but it won't offer much protection and the CF sheet will peel off over time
