Latest: ArtistKS
Overall: 17145
Online Now [73]:
Visitors: 72
Today: 13716
Total: 116047491
Forums › The Car › 206 Problems › 206 GTI SP 2000 issues after battery removed and jump starte
CDK62
PostPosted: Mon Jul 16, 2012 7:40 am Up
I have a Peugeot 206 GTI SP 2000 which was standing for a couple of months and the battery went flat, I charged the battery but it would turn over but would not fire up. I then jumped it from my other car and still no joy.
I looked online and found out about re-setting the BSI. I did what was discussed but no joy.
I had the car taken into Peugeot main dealer and they have said it could be the BSI or ECU and that because I jumped the car this had damaged because I jumped from a more powerful car and probably a power serge which I do not understand as these are fuse protected. They can replace the BSI but no guarantees and if it does not work then the ECU would need replacing.
Anyway would appreciate your advice if you agree , can they be fixed or replace with a re-furbished/2nd hand units or if has to be new how much would that be
206 GTI SP 2000
PostPosted: Mon Jul 16, 2012 7:53 am Up
this is definitely not the first time i have heard about after jump-starting the ecu was cooked
PostPosted: Mon Jul 16, 2012 8:00 am Up
Worse case scenario just replace the bsi, ecu and ring transponder will work fine
I probably have the correct set somewhere pm if you want it
PostPosted: Mon Jul 16, 2012 8:38 am Up
Did they check if ECU was unlocking?
Checked fuses and multifunction relay?
Doubt BSI will be knackered, probably just ECU. I've recently just sorted one for a guy on here for £140 that had a similar problem.
PostPosted: Mon Jul 16, 2012 8:49 am Up
If you have to replace the ecu mate, DO NOT go to Peugeot, I got a secondhand ecu, had it uncoded and then re-programmed for £230
PostPosted: Mon Jul 16, 2012 9:13 am Up
I have a complete ecu & bsi set off my 2000 gti for sale
PostPosted: Mon Jul 16, 2012 9:59 am Up
Expensive
CDK62
PostPosted: Tue Jul 17, 2012 3:44 am Up
Hi Lee, we are in Kent, near Orpington, is that anywhere near you that you could sort this one as well ?
Dave
206 GTI SP 2000
CDK62
PostPosted: Tue Jul 17, 2012 3:46 am Up
Hi Lee, How much would you be looking for, i was told that if i fit a 2nd hand one it will affect the mileage shown?
Dave
206 GTI SP 2000
CDK62
PostPosted: Tue Jul 17, 2012 3:48 am Up
Hi Harry, How much would that be ?
206 GTI SP 2000
PostPosted: Tue Jul 17, 2012 1:28 pm Up
Dave
Hi,
Is your ECU a Magneti Marelli IAW 48P.10?
