Latest: Stu-mill
Overall: 17131
Online Now [47]:
Visitors: 46
Today: 2762
Total: 104912438
Forums › The Car › 206 Talk › ENGINE CONVERSION COMPATIBILITY
Billykeish
PostPosted: Wed Jul 18, 2012 4:14 pm Up
[b]
HI THERE I NEED TO ASK A QUESTION...
has anyone tried fitting a 106 GTI/VTS engine in a 206???? will it work...??? thanks
bk
Big_Rich180
PostPosted: Wed Jul 18, 2012 4:18 pm Up
I dont see why it wouldnt as the 1.6 16v engines are pretty much the same dimensions as the 106 gti engine.
Although I dont know if the wiring would be an issue.
Not sure it would be worth it though.
Nic_206
PostPosted: Wed Jul 18, 2012 4:24 pm Up
isnt this engine the same as the xsi 16v's lump and anything is possible mate!
Ford focus st3 daily driver
Team: Red 20v6
Uz
PostPosted: Wed Jul 18, 2012 4:25 pm Up
Just do a jp4 engine conversion with loom and all. If your car is mux than buy the setup out of a mux car. If its pre buy it out of a pre car.
Matt
PostPosted: Wed Jul 18, 2012 6:11 pm Up
Trade Rating: +32
Hi Billy,
Just buy a 106GTi/VTS.
Simples.
NICKST
PostPosted: Thu Jul 19, 2012 12:21 am Up
Matt wrote:
Hi Billy,
Simples.
Or a 206 xsi will cost about same as engine conversion.
PostPosted: Thu Jul 19, 2012 2:15 am Up
If for some odd reason you really require having a 1.6 16v in a 206 without buying one buy an xsi engine then it will a straight fit don't get a vts one. You will need to change a LOT more - main issue being the wiring but I know the upper engine mount is in a totally different location for a start
Andrew
PostPosted: Thu Jul 19, 2012 5:31 am Up
206 XSI engine has bigger valves than the VTS/106 GTi. Makes less power mostly because of the cams and exhaust manifold
I'd say it would only be worth it if you can warrant the need to take the engine out (current one broken, building the XSI motor to a better spec on a stand, painting the engine bay etc), otherwise you'd be better off buying an XSI to begin with
My 206 thread
www.detailedbyandrew.com
