Latest: Kifi69
Overall: 17183
Online Now [318]:
Visitors: 317
Today: 4919
Total: 144152018
Forums › The Car › 206 Problems › help please
help please
anton1989
PostPosted: Tue Jul 17, 2012 3:52 pm Up
Trade Rating: +16
1st thing is, went to fit my 180 seats today and found the wire for the airbag had been cut off ( didnt notice before because old 206 nevr had seat airbags)
this what is left
there the ones on the seat, i was just going to conect them but the wires on the car are a different colour?
not sure if you can see but the seat has yellow, orange, and green/yellow the car has 2 orange and the earth(yellow/green?
what shall i do?
also found this conection under the drivers seat, not connected?
what is it for?
last question;
whats this for?
foundthis when takink the rear pannel off, also not connected?
PostPosted: Tue Jul 17, 2012 3:54 pm Up
Blue plug = cd changer.
White plug = seatbelt warning light
Does your car actually have side airbags fitted?
3rd Picture - CD Changer loom.
anton1989
Trade Rating: +16
edit
in the 2nd pic you can just about see the 2 orange wires i am on about
PostPosted: Tue Jul 17, 2012 3:56 pm Up
Look at the cables & find the id numbers.
anton1989
Trade Rating: +16
yes my new one does its a hdi 52 plate
the seat that were fitted ( also hadairbags) but that plug was not connected and there was no where to put it either?
anton1989
PostPosted: Tue Jul 17, 2012 3:58 pm Up
Trade Rating: +16
thanks will check this tommorow
PostPosted: Tue Jul 17, 2012 4:00 pm Up
Does the car even have side airbags set up?
Peel back the front door rubber at the base along the sill & look for a black 2 pin connector plug plugged in to a small black sensor that is bolted to the inner sill.
Its right in with the wiring loom.
If there is no sill sensor fitted then dont worry about the side airbags in the seats.
anton1989
PostPosted: Tue Jul 17, 2012 4:22 pm Up
Trade Rating: +16
yeah there is, saw it when i was going to wire my amp
PostPosted: Tue Jul 17, 2012 4:27 pm Up
Airbag warning light should be on then if the sill sensors are fitted & connected Confused
Has it had a smack & the airbag ecu been replaced with the wrong one?
anton1989
PostPosted: Tue Jul 17, 2012 4:32 pm Up
Trade Rating: +16
do you mean it should have been on with the white plug out? the wires on my old seat are fine ( the ones that came with the car) apart fromt that white plug not being in
edit
the wires on my 180 seats are the ones cut, and i want to put them in the car
PostPosted: Tue Jul 17, 2012 4:51 pm Up
The white plug is for the seatbelt warning lamp.
Did it leave the factory with side airbags?
anton1989
PostPosted: Tue Jul 17, 2012 5:34 pm Up
Trade Rating: +16
Oh wait my airbag light is on, its on the mfd saying airbag fault, sorry im new to the multiplex 206. Could the warning be because that lead is out? My horn does not work either? Was told could be comms 2000 though? Waiting till im off work to take it to the garage
PostPosted: Tue Jul 17, 2012 5:39 pm Up
Scan it with Peugeot Planet.
I'm not answering any more threads on here where the full problem information isn't posted at the start of the thread Rolling Eyes
PostPosted: Tue Jul 17, 2012 6:55 pm Up
In that case your going to be very quiet from now on Razz
