Latest: airmastertapes
Overall: 17133
Online Now [238]:
Visitors: 237
Today: 126189
Total: 106659763
Forums › The Car › 206 Problems › Biting Point Peugeot 206
CharlieAdshead
PostPosted: Tue Jul 24, 2012 6:43 pm Up
Hi guys, this is my first car and I am finding that I am constantly stalling in first as the biting point is really high up, making moving off slow and difficult, and hill starts are obviously even harder, how can I change this if that is possible?
Thanks.
swaynie
PostPosted: Tue Jul 24, 2012 6:46 pm Up
what model you got?
If your offended by my posts call\r\n0800 I dont care Wink
PostPosted: Tue Jul 24, 2012 11:59 pm Up
Learn to drive. Wink
Seriously - just go and drive the car more. Experience will help.
DeadEyePaul
PostPosted: Wed Jul 25, 2012 1:30 am Up
Add more acceleration
DJKaySee
PostPosted: Wed Jul 25, 2012 2:30 am Up
I had the same problem, Mine has had a fully re-conditioned gearbox, new clutch and new clutch cable, and my bite is also high up.
I have had people telling me the cable needs to be adjusted (if it can) Some tell me the bite should be low down and the rest say its because its a crappy French car.
Took me a while but got use to it, Although I would prefer it low down I don't think it can be altered as I was told its a hydraulic clutch?.
sig removed due to size
PostPosted: Wed Jul 25, 2012 2:46 am Up
You've had a new cable but someone told you it was a hydraulic clutch.
Thanks.
Every car you drive will be different, even if it's the same model. As Tom says, learn to drive it properly.
If it's still causing you an issue in a few weeks, sell the car and buy an automatic.
DJKaySee
PostPosted: Wed Jul 25, 2012 3:55 am Up
Ok I said that completely wrong, I was told it was an automatic clutch cable and it was and I quote "A b*****d". He said something about it automatically feeding in ? or something, cant remember word for word.
PostPosted: Wed Jul 25, 2012 8:13 am Up
Some 206 use a auto adjusting cable while others use a hydraulic set up.
Which one it is depends on what engine is fitted & also what side the steering wheel is on.
Until we know what engine is under the bonnet you aint got much hope of getting an answer.
DJKaySee
PostPosted: Wed Jul 25, 2012 8:27 am Up
Ah that sounds right, I was told its an auto adjusting cable on mine and its a 1.4L LX X Reg 2001.
PostPosted: Wed Jul 25, 2012 8:28 am Up
It will be an auto adjusting cable for that engine.
DJKaySee
PostPosted: Wed Jul 25, 2012 3:54 pm Up
Can The position of the bite point be altered on these ?
Deckchair5
PostPosted: Thu Jul 26, 2012 10:01 am Up
At a guess I'd say your new cable was installed incorrectly. Mine has a new cable and it bites almost exactly half way up in the clutch travel. With the new type cables you have to have the cable completely installed, including the bulkhead mounting bolts and only then release the adjusting mechanism to do its stuff
If you do it any other way around eg release the self adjuster block and then tighten the bulkhead mount bolts then you end up with a too high bite. You can make the bite point go higher but you can't make it go lower once it's ratcheted up the cable
If the bite point is so high up that the clutch is almost slipping all the time then I'd change the cable as it will wear out the release bearing very quickly if it's always in contact and constantly rotating. You should be able to pull the cable at the clutch fork end and measure the gap in the slack. If you can't get any slack at all then it's too tight and the cable needs changing
206 self adjusting cable
PostPosted: Thu Jul 26, 2012 10:05 am Up
.....and people like this pass their test...Jesus
Deckchair5
PostPosted: Thu Jul 26, 2012 10:21 am Up
Ha. Yes people do need to adapt to different cars but if the bite point is so high that you feel like just breathing on the pedal will make it slip then that's not good for the clutch and bearing and it's very likely the cable has been installed incorrectly on this one
PostPosted: Thu Jul 26, 2012 10:38 am Up
It doesn't take long to adapt at all, probably about two gear changes.
