Posted: Sat Jul 28, 2012 12:55 pm |
Just plugged my car into pp2000 and was suprised by the bsi faults and the fact alot of the readings did not reply. Such as my air con, multi display and sunroof which all work regardless.
Does anyone know why they are not replying i can read my enging ecu fine and bsi.
I also have a few analogue module short circuit faults and a permernant fault just sez ecu connection/ built in systems interface.
Id appreciate a translation of this if anyone knows.
Posted: Sat Jul 28, 2012 1:17 pm |
Cheap china clone? Probably why.
| Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling! | |
Posted: Sat Jul 28, 2012 1:24 pm |
Omg you must be psychic... Putting that aside can i trust these reading?
Posted: Sat Jul 28, 2012 1:34 pm |
Why buy something that you have no clue how to use?
Posted: Sat Jul 28, 2012 1:39 pm |
I know HOW to use it im computer literate. I didnt ask how to use it i asked about my bsi fault readings and whether i should trust my obd. Im gunna reset the codes and see if they come back.
Posted: Sat Jul 28, 2012 2:21 pm |
Obviously you don't if you don't know what the readings mean
Posted: Sat Jul 28, 2012 2:46 pm |
I didnt buy it my dad did to install cruise control on his peugeot partner. Im using it to reprogram my transponder key ... I dont care about the faultcodes i just want to know if there gunna give me grief.soi know how to use it for them things, just not what some of the fault codes mean. Its not hard to work out most of the codes ,i just listed those 2 which i did not understand.
