Forums › The Car › 206 Problems › 180 GTi Missing Breather Hose???? |
Posted: Thu Jul 26, 2012 10:46 am |
No idea if there is something missing here, but I cannot remember if I took something off or not, but I cannot find whatever went on here.
Can someone please check their 180 and let me know - bit odd that it goes direct to atmosphere - especially as it has clipped edges which to me means there should be something there.
It is on the exhaust side cam cover, gearbox end - not that you cannot see. There is nothing on the system at the local dealership...
Thanks in advance..
Posted: Thu Jul 26, 2012 11:47 am |
Is there a hole?
Posted: Thu Jul 26, 2012 12:09 pm |
yes - left hand side there is and then there is a hole the right of my red circle where it looks like it drains back into the head... but why would it... surely it goes full circle back to the inlet???
Posted: Thu Jul 26, 2012 12:10 pm |
Put your finger in it and you'll see it's nothing , it's only a breather on the gti 135
Posted: Thu Jul 26, 2012 12:12 pm |
thats how they are, there blanked off. some of the other ew engnies use the breather on the exhaust cam cover like that.
Posted: Thu Jul 26, 2012 12:19 pm |
Same on mine. 2004 180. Can see in this pic i took the other day
Posted: Thu Jul 26, 2012 12:36 pm |
Magic - thanks a lot dan...
And thanks rooney and simpson - but mine is not blanked off which is what threw me, but I won't loose sleep over it
..but you can see what I mean =)
Case Closed!!
Posted: Fri Jul 27, 2012 1:23 am |
There would be oil around the hole if the hose was missing.
Posted: Fri Jul 27, 2012 12:47 pm |
I have an oil catch tank and it's fed from that breather hole, if I took my hose off it would be very messy lol.
But it looks like its blanked off on the 180.
Posted: Sat Jul 28, 2012 5:04 am |
What can I say - guess mine is just different!!
And there is oil coming out of it!!!
Could just blank it off if everyone elses is...
