Posted: Fri Jul 20, 2012 10:56 pm |
My Peugeot 206 2003 is having a hard time downshifting it feels as if I am braking, and also it is hesitating in some gears.
I have changed my three engine / gear mountings (one right one left and one big down).
What could be the problem?
| At least you own your dream! | |
Posted: Sat Jul 21, 2012 3:57 am |
auto? manual?
Posted: Sat Jul 21, 2012 4:37 am |
When did you last get your gearbox oil replaced?
Posted: Sat Jul 21, 2012 8:52 am |
My car is automatic gearbox, and no I didnt change gear oil, I just got it one month ago. But I did go to a famous service shop and they said that we cant change oil of the gear box it shoud be done only in the dealer shop. Is changing gear oil simple? That i can do it my self? Is that a known fact for my gearboxb behaviour
Posted: Sat Jul 21, 2012 9:49 am |
The issue is, the auto gearbox ECU keeps track of the condition of the oil in a basic way, by counting the number of starts the car does, and the number of miles or time it runs (can't remember which). When you top it up, you're supposed to connect a computer to the auto ECU and tell it that you've done that, so it knows some new oil has gone in, and keeps track of the quality of the oil properly. So if you were to completely drain and refill it, you'd need to do this. The worst that could happen if you don't, though, is the computer would erroneously think the oil's 'worn out' and flash the sport and winter mode lights on the dash to indicate as such.
Posted: Sat Jul 21, 2012 9:55 am |
not every garage know how to deal with AL4 box.
go to auto gearbox specialist to deal with it.
ideally you need LT 71141 oil (need to keep changing oil a few times in order to renew all the oil ) and peugeot planet to do the oil change.
and most likely you might have to change the solenoid (s) or gear switch
Posted: Sat Jul 21, 2012 10:22 am |
The AL4 box is a load of w**k, why people dont do some research BEFORE buying a PSA car with it fitted ill never know
Wouldnt touch an AL4 with a barge pole.
Posted: Sat Jul 21, 2012 10:25 am |
MrBSI wrote: |
Wouldnt touch an AL4 with a barge pole. |
What do you do if you need an auto box, and want a 206?
Posted: Sat Jul 21, 2012 10:28 am |
paul_c wrote: |
MrBSI wrote: |
What do you do if you need an auto box, and want a 206? |
Autobox & 206 just isnt worth the trouble.
Nobody really wants a 206, there just a small cheap to run car that is average to drive.
Posted: Sat Jul 21, 2012 10:30 am |
What else similar size car (with auto box) do you recommend then? I have searched and searched, can't find another with similar power (110bhp) and auto.
Posted: Sat Jul 21, 2012 10:34 am |
paul_c wrote: |
What else similar size car (with auto box) do you recommend then? |
Do some research, internet is a wonderful tool.
Posted: Sat Jul 21, 2012 10:35 am |
MrBSI wrote: |
paul_c wrote: |
Do some research, internet is a wonderful tool. |
I did, and found nothing. I'd not be asking if I already knew.....
Posted: Sat Jul 21, 2012 10:40 am |
micra and yaris auto box are pretty decent
Posted: Sat Jul 21, 2012 10:47 am |
Seabook wrote: |
micra and yaris auto box are pretty decent |
Just watch the Jap lack of rustproofing on the body.
Posted: Sat Jul 21, 2012 10:50 am |
MrBSI wrote: |
Seabook wrote: |
Just watch the Jap lack of rustproofing on the body. |
i know my frds yaris is so rusty that even part of the sump is corroded away
