Online Now [417]:
Visitors: 417
Today: 111032
Total: 144931222
Forums › The Car › 206 Problems › can you adjust phase 2 washer jets?
GTI_89
PostPosted: Fri Aug 03, 2012 1:59 pm Up
as per title realy guys.
i replace my old washer jets with mk2 ones as 1 was blocked but the pasenger side one sprays to high and the drivers to low..
unlike to mk1 washers i cant see a way to adjust the spray pattern.. can you?
thanks,
Karl
Im New, Go Easy On Me Very Happy
PostPosted: Fri Aug 03, 2012 2:22 pm Up
Simple answer is no
jk206
PostPosted: Fri Aug 03, 2012 3:50 pm Up
no you cant as i have the same problem
-Dave-
PostPosted: Sat Aug 04, 2012 2:32 am Up
Trade Rating: +36
They are cheap enough just to buy a new set. Someone on here is selling gloss black ones on eBay for £8 delivered.
Ex 206 Owner.
PostPosted: Sat Aug 04, 2012 3:43 am Up
My N/S jet was too low just before the MOT. Took it off, gave it a clean and blasted compressed air through it and it sorted the problem. I think it was polish residue slightly blocking the jet.
Might sound daft, but try swapping them over N/S to O/S. They are not sided, but might improve a little bit if the bonnet is slightly warped.
