Latest: lio94
Overall: 17181
Online Now [436]:
Visitors: 435
Today: 19980
Total: 141774886
Forums › The Car › 206 Problems › Fuel tank leaking from sender unit
cosmicdance
PostPosted: Thu Jul 26, 2012 1:49 pm Up
Hi
My Peugeot 206 1.4 HDI 2002 is leaking fuel from the top of the sender unit when the tank is filled right up.
I have replaced the silicone O ring and put a new plastic O nut on but it still leaks.
I wondered if it is leaking from the actual sender unit now?
Andy
Andy
PostPosted: Fri Jul 27, 2012 1:29 am Up
You have to push it very strong before you the plastic nut on,other wise it will keep leaking
cosmicdance
PostPosted: Fri Aug 03, 2012 3:31 am Up
Well I tried pushing it down hard and replaced the silicone seal and O ring but still leaked.
I got a new sender unit and it's fine now so must have been leaking from that.
It started a couple of weeks ago when I filled the tank right up so must have just worn away over time.
Thanks for your help anyway.
Andy
Andy
