Posted: Fri Aug 03, 2012 2:23 am |
got this in pp2000 the other day .. keeps coming back .. any ideas?
Automatic Transmission Control Unit.
Intermittent Fault. Press Control Signal Fault
Any insight would be great thanks ![Smile Smile](images/smiles/icon_smile.gif)
| | ![](images/spacer.gif) |
Posted: Fri Aug 03, 2012 5:37 am |
new solenoids will fixed that
Posted: Fri Aug 03, 2012 5:38 am |
Got a fault code? I guessing its automatic?
P0819 Press control signal fault : Change of position impossible
P0826 Press control signal fault : Stuck in M+ or M-
Posted: Fri Aug 03, 2012 5:51 am |
its automatic yea .. didnt get a code with it . just got that in pp .. new solenoids ?
Posted: Fri Aug 03, 2012 5:55 am |
After youve scanned for codes, highlight the fault and press f6 it will give you the code. How are the gear changes? Can you select the manual option, and use it?
Posted: Fri Aug 03, 2012 6:51 am |
yea can use semi mode .. but when its in drive its abit iffy .. sumtimes holds onto 2nd to long ..
