Latest: Beduff1977
Overall: 17134
Online Now [888]:
Visitors: 887
Today: 34746
Total: 107436449
Forums › The Car › 206 Problems › gti180 rear knocking noise
kingofcatastrophe
PostPosted: Fri Aug 03, 2012 7:20 am Up
over recent weeks there's been a twanging/knocking noise coming from the back of my 180, we've had it all apart and back together, nothings loose...
Can't work it out and its doing my tits in. Confused
Automotive Photographer.
jk206
PostPosted: Fri Aug 03, 2012 7:57 am Up
Boot lid? Rear axle? Spare wheel cage? (if it has one)
PostPosted: Fri Aug 03, 2012 8:17 am Up
A metallic twanging noise can often be the anti roll bar bolts being loose or the end plates need hammering on a mm or two more.
GuyGTI
PostPosted: Fri Aug 03, 2012 8:58 am Up
My 137 has the same problem, been to 4 different garages and still cant get to the bottom of it!
206 superchiped GTI
