Posted: Thu Aug 09, 2012 12:46 am |
Hi
I have recently purchased a 2005 Peugeot 206 1.4 HDI so I am unfamilier with how it should sound!
There seems to be a lot of road noise when driving along and gets louder the faster I go, is this normal for the 206?
Its still there when I take it out of gear.
I have just had a Full service and MOT and the mechanic said the bearings are fine when he listen to them with a Tethascope.
Apart from the noise its a great little car.
Any advise please?
Posted: Thu Aug 09, 2012 1:14 am |
Could be crap tyres or you are used to something with better quality.
Posted: Thu Aug 09, 2012 1:45 am |
As said tyres make a big difference. They're not the quietest cars to be in anyway though. I would have thought the tyres are the main factor to be honest if everything's mechanically sound.
Posted: Thu Aug 09, 2012 10:34 am |
DanT wrote: |
They're not the quietest cars to be in anyway though. |
As I get older the road noise of my 206 starts to annoy me more, just reminds me next time to get something better built with more sound proofing.
Posted: Fri Aug 10, 2012 2:15 pm |
Get a decent/loud audio set-up.
Problem solved.
| 2002 1.6 5dr Black Edition. | |
Posted: Fri Aug 10, 2012 2:22 pm |
devildriverxii wrote: |
Problem solved. |
still the same. too noisy in the cockpit
Posted: Fri Aug 10, 2012 6:17 pm |
Seabook wrote: |
Problem solved. |
still the same. too noisy in the cockpit  |
Plus a big sub will just cause more rattles...
Posted: Sat Aug 11, 2012 1:53 am |
Dont notice any road noise at all in mu 206....
Posted: Mon Oct 29, 2012 4:46 am |
I have now fitted Alloys and the road noise has been greatly reduced.
Thank god for that as I thought maybe the rear axle bearings were on there way out!
Posted: Mon Oct 29, 2012 10:42 am |
A10PSW wrote: |
I have now fitted Alloys |
With the WRONG wheel bolts
Posted: Mon Oct 29, 2012 10:50 am |
MrBSI wrote: |
A10PSW wrote: |
With the WRONG wheel bolts  |
They hold the wheels on!!
Just ordered some longer ones!
Posted: Mon Oct 29, 2012 10:52 am |
A10PSW wrote: |
MrBSI wrote: |
A10PSW wrote: |
Just ordered some longer ones! |
They wont for long
