Latest: airmastertapes
Overall: 17133
Online Now [114]:
Visitors: 113
Today: 15077
Total: 106679313
Forums › The Car › 206 Talk › Chrome wheel nuts/caps
Mounty
PostPosted: Thu Aug 09, 2012 2:26 pm Up
Just bought my first 206 this week.
No manual with it, just a wheel brace & no jack.
I've been looking at the wheel nuts on the alloys and these look like chrome plastic caps? Just wondering how I get these off as no tool with the car and caps are too big for wheel brace.
Any help appreciated
2001 206 Gti - Original & Unmolested
1994 Renault 5 - Production Car Trials
L5_UKS
PostPosted: Thu Aug 09, 2012 2:28 pm Up
Welcome along Waving o/
Just a long nose pair of pliers or if what I do if I haven't got one a set to hand is use 2 coins put one of either side and pull them out Wink
PostPosted: Thu Aug 09, 2012 2:41 pm Up
Should be a yellow plastic tool clipped to the wheel brace for removing the caps on the alloy bolts.
The jack lives inside a plastic box, lower the spare wheel down & you should find it inside there Wink
Also a good idea to grease up the wheel cage lowering bolt as they rust up.
Mounty
PostPosted: Sat Aug 11, 2012 2:51 am Up
Ok, cheers to both of you for advice. No yellow tool in car so will have a look in the spare. Had only tried with my fingers to get caps off so no real effort been applied yet.
Are the bolt hole spacings on the Pug 4 x 108?
DeadEyePaul
PostPosted: Sat Aug 11, 2012 3:41 am Up
Yes 108x4
I use a flat bladed screw driver to lever them off at all angles.
The jack the car comes with is rubbish and will break with 1-2 uses. Probably why you dont have one?
Invest in a trolley jack and some axle stands, well worth it
PostPosted: Sat Aug 11, 2012 3:59 am Up
The standard jack is perfectly fine for it's intended use of changing a wheel at the roadside IF its used CORRECTLY.
rosewel
PostPosted: Sat Aug 11, 2012 12:08 pm Up
Maybe i should have a look and see if i have a jack, i've never thought of looking Embarassed
I have a 206 HDI Van 2006. I can honestly say i love my van ♥
Mounty
PostPosted: Sat Aug 11, 2012 3:29 pm Up
I can confirm that long nosed pliers work a treat with the caps. Very Happy
Have got a trolley jack so just need a pair of axle stands, don't like the creaking noises when its suspended by just the jack.
Have had a thorough inspection today so now posting a new topic with a few questions.
See 'First Inspection' thead
