Latest: tbafonso
Overall: 17130
Online Now [105]:
Visitors: 105
Today: 15437
Total: 102372885
Forums › The Car › 206 Talk › Removing window glass
sam-c
PostPosted: Tue Aug 14, 2012 2:55 am Up
Yorkshire Area Rep - SamC
Hi guys another quick one from me.
How do I remove the glass from the front doors? They are electric windows if that makes a difference?
Sam
Barking
PostPosted: Tue Aug 14, 2012 3:17 am Up
Presumably you rip the interior door panels off and remove the glass from the window lifter. Apart from damaging the door frame there's no other way.
I got a dig bick.
You that read wrong.
You read that wrong too.
PostPosted: Tue Aug 14, 2012 3:28 am Up
Park in Salford and leave your satnav attached to the screen. They will remove your glass in 2 seconds.
Presuming you've already removed the door card, remove the inner seal strip at the top of the door, position the window about 3 quarters down and unclip the window from the guides and lift out through the top. No damage to door needed.
VorTechS
PostPosted: Tue Aug 14, 2012 3:30 am Up
Staff - Vortechs
- Take the door card off
- With the door card off, operate the window so that the holder moves into such a position as you can get access to the glass holders
- Push against the holders (plastic nubs) to free the glass (Caution: Requires some force - so be careful!)
- Remove the lower part of the window seal
- Lift the glass out
When lifting the glass out, you'll find rotating it 90 degress makes it easier to get out!
iainlovatt
PostPosted: Tue Aug 14, 2012 4:45 am Up
Use a screw driver to push the white clips off the glass carefully,, 2 second job!!
(My Garage)
PostPosted: Tue Aug 14, 2012 5:20 am Up
iainlovatt wrote:
Use a screw driver to push the white clips off Ye mirror glass carefully 2 second job!!
2 seconds for the mirror glass, but the OP wants to know about window glass
RTFQ springs to mind.
iainlovatt
PostPosted: Tue Aug 14, 2012 7:34 am Up
was doing it on my mobile didnt mean to put "mirror" in! lol!
sam what are you up2?
(My Garage)
PostPosted: Tue Aug 14, 2012 8:10 am Up
iainlovatt wrote:
member since April 2005 (Now the longest member on here by far)
I'm pretty confident I can beat that...
iainlovatt
PostPosted: Tue Aug 14, 2012 11:05 am Up
Go on how? When did u first join dude?
(My Garage)
PostPosted: Tue Aug 14, 2012 12:49 pm Up
Well Ive had the 206 since 2003...I was on the really old 206info years back.
iainlovatt
PostPosted: Tue Aug 14, 2012 1:39 pm Up
Fair enough dude, Guess im the second longest.
We have both been through some big changes on the site, Smile
(My Garage)
PostPosted: Tue Aug 14, 2012 1:49 pm Up
Just checked the old 206info exchange....30th November 2003!
iainlovatt
PostPosted: Tue Aug 14, 2012 2:07 pm Up
How?
(My Garage)
PostPosted: Tue Aug 14, 2012 2:08 pm Up
Scale 1:1
You'll need this if your going to compare d**k sizes.
And just for the record, I have bigger tits than your two mums put together
iainlovatt
PostPosted: Tue Aug 14, 2012 2:12 pm Up
Look who's jumping into compare,
(My Garage)
