Latest: airmastertapes
Overall: 17133
Online Now [463]:
Visitors: 462
Today: 66899
Total: 106778762
Forums › The Car › 206 Problems › Startup Issue
Startup Issue
kewlnsol
PostPosted: Tue Aug 14, 2012 7:02 pm Up
Hi guys nice site okies help appreciated here
Have a 206 GTI 2.0 130BHP `99 model, have changed engine on it, engine started up fine was running 20 mins or so on axle stands, after a bit it died and when i try to start it now i get a loud clicking from the ECU, the ECU Light flickers in time with the clicking and the fan comes on automatically,
The engine seems to turn over fine without any wierd noises ect. but soesnt fire.
I deliberatly trip the shunt switch and the ecu doesnt click but again engine still turs but doesnt fire up.
Any ideas ?
You Tube vid of Pug in action
hello
PostPosted: Tue Aug 14, 2012 8:36 pm Up
Sounds like a trapped wire somewhere OR a wire connected up wrong.
I'm sure someone on here has had similar before where they have connected a wire wrong when swopping the lump.
Recheck wiring carefully, make sure you haven't trapped anything / put a wire somewhere it shouldn't be.
Make sure the ecu isn't missing any of its earths on the connector plug.
Trip switch tripped will stop power going to fuel pump & you say this stops the ecu clicking so check the wiring under the bonnet / double relay under ecu.
kewlnsol
PostPosted: Wed Aug 15, 2012 2:37 am Up
cheers for info, the engine was running and starting fine then suddenly decided to play up so wont be a wrong connecter plugged in somewhere, will check ground srtaps ect. today, how do i get to the underneath of the ecu as they have tamper proof bolt heads to stop u moving them ?
hello
kewlnsol
PostPosted: Wed Aug 15, 2012 5:02 am Up
okies - issue resolved, running the engine on axle stands had shaken the earth strap from gearbox to body off the bolt now tightened and working fine Very Happy thanks for the help on to my next issue
hello
