Latest: tbafonso
Overall: 17130
Online Now [46]:
Visitors: 45
Today: 5423
Total: 104130238
Forums › The Car › 206 Talk › Spaced...
Spaced...
benkeeganbmx
PostPosted: Wed Sep 10, 2014 11:52 am Up
soooo I finally bit the bullet.... and went and got some hubcentric spacers from JCC R&R
please to say I'm actually stoked on how they make th car look now. The rear track has always looked a it gash on standard wheels, abit too narrow for the look of the cars when lowered. So I went 20mm each side on the front and 15mm each side on the rear
Yeah I know they arn't got for the wheel bearings and what ever but I'll just suck it for a while Smile
Opinions on these?
www.dropbox.com/s/c2up...0.jpg?dl=0
www.dropbox.com/s/b73f...1.jpg?dl=0
\'\'if you believe you can do something, then go and do it, because its the only way your going to get it. Make it happen\'\' - Harry Main.
Leegsi
PostPosted: Wed Sep 10, 2014 2:53 pm Up
Looks loads better
PostPosted: Wed Sep 10, 2014 3:46 pm Up
As a result your suspension will be slightly softer than before.
benkeeganbmx
PostPosted: Wed Sep 10, 2014 4:52 pm Up
I have noticed this tonight ed... Care to explain?
