Posted: Tue Aug 28, 2012 3:18 am |
So my peugeot 206 just failed the MOT on the following problems , and any help with estimations would be great:
001 Offside front Anti-roll bar linkage ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt.
002. Nearside front lower suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt.
003. Offside front lower suspension arm ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt.
Im based in Tunbridge Wells, Kent so if anyone knows of any good local mechanics that would be great too.
| peugeot 206, sapphire blue, 2001. | |
Posted: Tue Aug 28, 2012 3:21 am |
all that is just wear and tear, especially on a 2001 car ,, anti roll bar would be about £25 i would of thought! inc fitting,
Posted: Tue Aug 28, 2012 4:12 am |
Hi,
Thanks for the reply! Really £25 for the bar and fitting!? seems cheap! Do you have any idea on costings for the 002 and 003, because i presume i will need them repaired to pass my test
Posted: Tue Aug 28, 2012 4:18 am |
about £150 inc labour so just under £200 at a guess! parts are around £40 quid for 002 and same for 003 and £70 labour! Did they not give u a price when u were there to fix it?
Posted: Tue Aug 28, 2012 4:26 am |
£200. & don't forget if you use the MOT garage for repair you want a free re test.
Posted: Tue Aug 28, 2012 7:00 am |
| E5GDM wrote: |
| £200. & don't forget if you use the MOT garage for repair you want a free re test. |
Unless its like where i took mine, failled it for free paid them when it passed
Posted: Fri Aug 31, 2012 1:55 am |
If you wishbones bushes and ball joint still in good condition, u can change the rubber dust cover. They are only £5 from ebay (only if your wishbones in good condition and your garage agree to carry out the work for u)
Posted: Fri Aug 31, 2012 11:53 am |
Most MOT places allow a week to get the work done and get the car back to them for free retest ... they don't have to do the work.
