Latest: cogeim7
Overall: 17185
Online Now [563]:
Visitors: 562
Today: 7681
Total: 147134880
Forums › The Car › 206 Talk › Wiring loom
Wiring loom
Forum Index › 206 Talk
PezHdi
PostPosted: Fri Aug 31, 2012 12:03 pm Up
does any one no if the 1.6 HDI and the 2.0 HDI run the same wiring loom? Smile
Cheers Pez
EXL Pez
PostPosted: Fri Aug 31, 2012 12:17 pm Up
No, I doubt it
Squeaker
PostPosted: Fri Aug 31, 2012 12:29 pm Up
What wiring loom are you after?
PezHdi
PostPosted: Fri Aug 31, 2012 12:32 pm Up
I'm not after a loom I just Wondering if the looms are the same? Im pretty sure the 1.6 HDI has a oxygen sensor but i no the 2.0 HDI hasn't.( I Have a 2,0) I would was wondering if its possible wire one in :] I might be mistaken tho :]
EXL Pez
Squeaker
PostPosted: Fri Aug 31, 2012 12:35 pm Up
i don't know, but i'm breaking my 1.6hdi so got the looms Smile
PezHdi
PostPosted: Fri Aug 31, 2012 12:41 pm Up
Pm sent squeaker :]
EXL Pez
PostPosted: Fri Aug 31, 2012 2:52 pm Up
Why would you want to wire one in?
jackspaniels
PostPosted: Fri Aug 31, 2012 3:18 pm Up
Yeah, why?
PEUGEOT 206 V6 FOR SALE !!!!
as seen on YOUTUBE
TEXT ME ON :07528810462
PezHdi
PostPosted: Fri Aug 31, 2012 3:31 pm Up
Well an oxygen sensor / lambda sensor makes the mix between the fuel and the air a bit more equal which means it will produce less smoke ( not that there is a lot anyway ) And should there for not waste as much fuel.
That's the way i see it any way Smile
Smile
EXL Pez
PostPosted: Fri Aug 31, 2012 3:54 pm Up
The ECU would need the capability of doing something with the lambda signal...which it won't have.
PezHdi
PostPosted: Fri Aug 31, 2012 4:01 pm Up
yeah i no that but could i use the software from the 1.6 HDi aswell?
As mine will have an intercooler soon enough :]
Its just an idea that i had that's all.
This is why im asking so i dont need to buy the parts if it wont work? :]
EXL Pez
PostPosted: Fri Aug 31, 2012 5:21 pm Up
am i the only one got confused here?
i seriously doubt 206 1.6 HDi has lambda sensor; although newer diesel engine which meet euro 5 emission might have one.
diesel lambda are way more expensive than those in petrol since diesel run very wide air fuel ratio; from over 200:1 when idle up to something like 15:1 or even richer under full throttle. Diesel fuel got anti foaming agent and will f*** up cheap sensor in a sec! Not to mention without proper DPF the soot produce will f*** up the lambda in no time.
And more important; like edward said above. your ecu will not be able to run lambda. and you can't swap the ecu.
PezHdi
PostPosted: Fri Aug 31, 2012 5:28 pm Up
Good good i'm Glad we have finally have an answer :] Like i said it was just an Idea :]
But i can tell you that a 1.6 HDi GTI has a lambda / Oxygen sensor :]
And also i was going to swap the ECU just upload / Upgrade the Ecu.
But as you have said it wont work.
cheers again :]
EXL Pez
PostPosted: Fri Aug 31, 2012 5:39 pm Up
cheers again :]
oh yes.. found it..like i said it is plug onto the DPF Laughing
PezHdi
PostPosted: Fri Aug 31, 2012 5:43 pm Up
yeah it is Pluged in to that stupid DPF system :]
Can you see what i was thinking now?
Il do some reserch and see what i can come up with but for now its a NO NO :]
EXL Pez
