Latest: tbafonso
Overall: 17130
Online Now [266]:
Visitors: 265
Today: 16089
Total: 103751905
Forums › The Car › 206 Problems › Peugeot 206 Battery light on and indicators stopped working
jonchern
PostPosted: Thu Aug 30, 2012 5:33 pm Up
Hi since disconnecting and reconnecting the battery the battery light now stays on and the indicators have stopped working. The hazard lights work ok.
Can anyone suggest what the problem is please
PostPosted: Fri Aug 31, 2012 9:48 am Up
Sod all information given about the 206 in question as usual on here, 2 totally different types of electrical systems used, one simple & one digital CAN VAN.
Its most likely multiplexed, reboot the BSI unit correctly.
If your lucky you wont have done any damage by disconnecting / reconnecting the battery & not following the correct BSI shut down / reboot procedure.
jonchern
PostPosted: Fri Aug 31, 2012 2:38 pm Up
Ok this will help though at present I have to disconnect/reconnect the battery as the ignition switch has jammed in the start position with key in the lock. Can't get it out
Hopefully when the ignitions fixed i'll be able to try your suggested reboot of the BSI
Thanks for your help
