Latest: Beduff1977
Overall: 17134
Online Now [651]:
Visitors: 650
Today: 193360
Total: 108128389
Forums › The Car › 206 Problems › Brake Disc Help!
Brake Disc Help!
Simon2710
PostPosted: Sun Sep 23, 2012 8:08 am Up
Hi,
I have just bought some QH (Quinton Hazell) brake discs from my local motor factor. I didn't really pay much attention to detail so if the part is incorrect that's my fault! I have put the front brake discs on fine, but the caliper won't fit? It fit the old brake discs. Could this be because these may be rear brake discs they have given me (my rear brakes are drums) or just the incorrect part. I'm also not sure whether my car is 16v or 8v which might also be a problem. I have a 206 1.6 GLX 2000. Anyway I could find this out? And could someone please provide a link to maybe Ebay/another site with correct front brake discs please?
Many thanks!
Simon
Andrew
PostPosted: Sun Sep 23, 2012 8:12 am Up
The discs would be smaller than the old ones if they gave your rear ones. Chances are you've been given discs for another peugeot like a 307, which use the same diameters, but will have the wrong offset causing the disc to sit further in or out than the correct ones. Take them back for a swap, they should be obliging to help you.
My 206 thread
www.detailedbyandrew.com
jk206
PostPosted: Sun Sep 23, 2012 8:13 am Up
Disc must be slightly thicker than the stock disc, you will need new calipers
Simon2710
PostPosted: Sun Sep 23, 2012 8:17 am Up
Thanks for the replies, any ideas on calipers and where I can get these? The brake discs seem correct, on the box it states 206 1.6i?
Simon
DeadEyePaul
PostPosted: Sun Sep 23, 2012 8:20 am Up
Did you move the caliper pistons back before removing old discs?
PostPosted: Sun Sep 23, 2012 8:25 am Up
Might be the wrong offset. The gti 138 changed offsets around 2002. Just take them back if there wrong. Are they vented or solid?
PostPosted: Sun Sep 23, 2012 8:35 am Up
check the box to see if there is any parts number on it.
you need 266x20.5 disc
Simon2710
PostPosted: Sun Sep 23, 2012 8:46 am Up
This is before I actually put the piston back on. The caliper that holds the brake pads won't fit.
Simon
Simon2710
PostPosted: Sun Sep 23, 2012 8:49 am Up
Thanks, part number from the box says: BDC3508P
Simon
PostPosted: Sun Sep 23, 2012 9:00 am Up
that looks like the right disc to me....
have you got the vin? i can check if you got the correct disc?
and have you got the pics of your brake pad? does it got a round end or square end?
Simon2710
PostPosted: Sun Sep 23, 2012 9:02 am Up
Yes I'll PM you it, thanks!
Simon
PostPosted: Sun Sep 23, 2012 9:08 am Up
yes. you got the wrong disc....
you need 247x20.5 disc.
4246 A7 or 4249 96
Simon2710
PostPosted: Sun Sep 23, 2012 9:12 am Up
4246 A7 or 4249 96
Ooops. What about these then - www.eurocarparts.com/e...amp;000027
Simon
that looks right to me
Simon2710
PostPosted: Sun Sep 23, 2012 9:20 am Up
Thanks, won't be using that motor factors again! He actually took a book out, I told him all the info (year, engine size etc.). Although why does it say Peugeot 206 1.6i on the box if it doesn't fit? Is it possible this is for newer models?
Simon
