Latest: S2cgm
Overall: 17178
Online Now [203]:
Visitors: 201
Bots: 2
Today: 37662
Total: 137307226
Forums › The Car › 206 Problems › Pug 206 over heating possible head gasket cont'd....
nmj37
PostPosted: Fri Aug 31, 2012 1:07 pm Up
Seabrook kindly gave me some advice lastnight on my 1st post and I am reposting as I'm with the car this evening.. Finding it difficult on iPhone..
www.206info.co.uk/Foru...49226.html
When I start the engine there is fumes coming out of the water tank and cannot screw the cap on fully for long w/o enormous pressure build up.
Do the fumes coming out this way signify a blown head gasket?
Also took very long time to start the engine but gradually got there after using accelerator too..
PostPosted: Fri Aug 31, 2012 2:16 pm Up
well you need a compression test then..
jackspaniels
PostPosted: Fri Aug 31, 2012 3:15 pm Up
Head gasket is gone, compression test WILL confirm this.
It is hard to start as water is leaking into cylinder/s whilst it is parked.
Cap won't go on because the combustion is leaking into water jacket.
Block test kit will also confirm this.
Do not try quick fix treatments, they will not work.
It's possible the liner is cracked (but not likely) but head will have to come off.
Or replace the engine.
PEUGEOT 206 V6 FOR SALE !!!!
as seen on YOUTUBE
TEXT ME ON :07528810462
Rob2859
PostPosted: Fri Aug 31, 2012 6:43 pm Up
It would probably be cheaper to drop another engine in it depending on what you have. I would find out why it is overheating before anything else.
