Online Now [62]:
Visitors: 61
Today: 4175
Total: 104977208
Forums › The Car › 206 Talk › Need slight help with wiring Morette lights
mehoolkmusic
PostPosted: Mon Sep 03, 2012 11:44 am Up
Evening info'ers, I've got the morette lights now, however I just want to clear a few things up.
Firstly have I wired them up correctly? On both sides the Dipped beam (Yellow plug is left) Am I right saying they have to be ground?
Secondly I have a dead moth inside the lamp, how do I remove this little shi*? Lol.
Sorry if this has been asked soo many times! I found CD-B3's helpful guide, but the rest of the pictures wern't loading up Evil or Very Mad
My car is a 2004, to clear things up :).
Thank you
Left French. Drive a Astra coupé 2004
www.soundcloud.com/mehoolkmusic
PostPosted: Mon Sep 03, 2012 11:47 am Up
pics are bit small to tell but in top pic do u have a loose yellow wire?
just plug them in and find out of the work, worse that can happen is blow a fuse Laughing
mehoolkmusic
PostPosted: Mon Sep 03, 2012 11:49 am Up
Yeah on both lamps ben the yellow wires are loose
PostPosted: Mon Sep 03, 2012 11:50 am Up
iirc they need to be earthed, will go have a look at mine in a min see what there like.
DeadEyePaul
PostPosted: Mon Sep 03, 2012 11:52 am Up
Both sets need to be earthed there is a bolt next to where headlights sit that you can use... At a guess that's what the yellow wire is for but I can't look at mine to compare
mehoolkmusic
PostPosted: Mon Sep 03, 2012 11:54 am Up
Here are some bigger pictures
mehoolkmusic
PostPosted: Mon Sep 03, 2012 11:55 am Up
F*** Came out wrong again! lol
138Andy
PostPosted: Mon Sep 03, 2012 12:23 pm Up
Looks good just earth it
iainlovatt
PostPosted: Mon Sep 03, 2012 2:10 pm Up
looks fine to me just passenger one needs power and earth, and drivers one needs an earth too, just use the earth that the light loom are on now,
(My Garage)
mehoolkmusic
PostPosted: Mon Sep 03, 2012 2:38 pm Up
Thanks guys! I appriciate it will post pics up once the covers arrive Very Happy
mehoolkmusic
PostPosted: Wed Sep 05, 2012 8:50 am Up
Ok problem lol the driver one works perfect however the passenger one the dipped beam ain't working I need help ASAP as im doing it now! Lol cheers!
PostPosted: Wed Sep 05, 2012 2:02 pm Up
is it earthed correctly? bulb ok?
mehoolkmusic
PostPosted: Wed Sep 05, 2012 2:04 pm Up
The yellow wire I've slotted it under the cover where the nut is, as the other side I've done the same..
mehoolkmusic
PostPosted: Wed Sep 05, 2012 2:07 pm Up
Bulbs work fine as I've put the crystals back in,
PostPosted: Wed Sep 05, 2012 2:38 pm Up
But is the bulb in the morrete ok? Could be a knackered bulb, if the full beam works im sure its a knackered bulb.
