Online Now [551]:
Visitors: 550
Today: 126706
Total: 105568648
Forums › The Car › 206 Problems › fault codes p075 p011p012
davand25
PostPosted: Mon Sep 03, 2012 8:30 pm Up
hi fokes
just bought a 206 gti 180 for the missus.
took it for a run and the engine felt totaly flat, no power at all! so took it to the garage and put it on the computer and it brought up these codes
p075 p011 p012.
anyone had this before??
cheers guys
PostPosted: Tue Sep 04, 2012 1:53 am Up
P07xx - Transmission Faults
P01xx - Fuel and Air Metering
I'm taking a guess that there is a digit missing in the codes
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0011 A Camshaft Position - Timing Over - Advanced or System Performance (Bank 1)
P0012 A Camshaft Position - Timing Over - Retarded (Bank 1)
Ideally you could do with getting hooked up to PP and having the codes read properly. Looks like the garage just used a generic code reader
davand25
PostPosted: Tue Sep 04, 2012 3:29 am Up
woops!!!! yes thats the ones
thanks mate
PostPosted: Tue Sep 04, 2012 4:48 am Up
www.206info.co.uk/Foru...codes.html
davand25
PostPosted: Tue Sep 04, 2012 6:53 pm Up
im thinking its the "DREADED SOLENOID" problem on the gti 180s. just wonderd if anyone had these fault codes with this problem.
actual codes were P0075 P0011 P0012. ( my mistake in the heading)
PostPosted: Mon Oct 08, 2012 12:56 pm Up
by any chances you just change the timing belt?
davand25
PostPosted: Tue Oct 09, 2012 9:59 am Up
i havnt no, but not sure if it has had a new belt put on in the past, but sum1 else did suggest that it might b a tooth out possibly.
Schumi
PostPosted: Tue Oct 09, 2012 11:57 am Up
Damaged VVT pulley or VVT selenoid.
2005 206 RC RED
