Online Now [1071]:
Visitors: 1070
Today: 100960
Total: 146555887
Forums › The Car › 206 Problems › Tappet adjustment on HDi?
Abzynthe
PostPosted: Tue Oct 09, 2012 8:00 am Up
East Area Rep - Abzynthe
Howdo,
Im not very clued up on engines and how they work, but my 2.0HDi makes a very tappy noise that gets quicker the more I rev. Now on my old 1.6 petrol, it was the same and I was told the tappets need adjusting, Would this be the same for the Diesel?
Nathan
PostPosted: Tue Oct 09, 2012 8:10 am Up
you can't. it is self adjusted
Abzynthe
PostPosted: Tue Oct 09, 2012 8:18 am Up
So what could it be? It sounds exactly like my old Petrol :/
PostPosted: Tue Oct 09, 2012 9:18 am Up
New set of tappets
cartoonhead
PostPosted: Tue Oct 09, 2012 9:49 am Up
have a listen if its louder on the drivers side.
if it is then it could be either the aux belt tensioner or the crank pully as they both tap when on the way out Wink
PostPosted: Tue Oct 09, 2012 10:02 am Up
may also check the oil level as well.....
mine tape really badly if the oil is near the lower end of the dip stick,
plus it tapes badly if certain brand of engine oil is used.
Abzynthe
PostPosted: Tue Oct 09, 2012 10:36 am Up
Cheers, Ill check all the above Smile
