Posted: Mon Dec 03, 2012 2:36 pm |
Hey guys, as some as you know just had clutch fitted, 206 is running so smooth now but whenever im driving and push the clutch in when coming to a stop there's slight engine Rev.
I noticed there's a screw maybe a limit screw on the accelerator do i release some tension or?
Posted: Mon Dec 03, 2012 2:39 pm |
Probably picks up a few revs because it's not having to spin the gearbox internals.
Posted: Mon Dec 03, 2012 2:40 pm |
Normal then or? As its idling just over x100
Posted: Mon Dec 03, 2012 2:59 pm |
I thought all modern cars held there revs for a second when you engage the clutch
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Mon Dec 03, 2012 3:11 pm |
How modern 1999? Could be me i guess
Posted: Mon Dec 03, 2012 4:49 pm |
Idle should be 750rpm after 10 minutes from cold +/- 50rpm.
Don't mess with the throttle cable at all.
Get used to driving it and see if it's you or the pug at fault.
Posted: Mon Dec 03, 2012 5:17 pm |
NayNay1991x wrote: |
The engine ecu is programed to do that.
Engine ecu sees the car is still moving from the speed sensor so it raises the idle speed slightly.
Posted: Tue Dec 04, 2012 2:05 am |
Isnt it supposed to help from what i read, as you shift from 1st it climbs abit to get in 2nd
Posted: Tue Dec 04, 2012 10:11 am |
Race car drivers often give it a.blip before selecting a gear.
