Latest: Stu-mill
Overall: 17131
Online Now [58]:
Visitors: 58
Today: 18971
Total: 104906560
Forums › The Car › 206 Talk › 206 Injectors ?
206 Injectors ?
SteveTDCi
PostPosted: Thu Sep 06, 2012 3:51 am Up
Are the 206 injectors all the same ? There is a second hand set on ebay that are from a 1.4 8v 206 and from the year 99/00 exactly the same as mine. Its difficult to see in the pictures but they possibly look black where my injectors are light grey ?
I just wondered if there was any difference. I realise larger engines will be different but didn't know if it would be simliar across the 1.4 range. Its the injector rail and loom all included thats being sold for £45.
If they are worth a punt i'll go and get them as they are local. Oh and do pug dealers tend to stock the seals ? they only look like basic o rings to me. And is the injector rail easy to swap and noi special tools needed ?
Cheers guys
Steve
206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out
PostPosted: Thu Sep 06, 2012 4:31 am Up
easy job to change over, seals can be found in most motor factors if unable to source any, no special tools are needed.
SteveTDCi
PostPosted: Thu Sep 06, 2012 4:57 am Up
cheers ben, any idea if the black and grey are interchangable ? I'm told they should be.
PostPosted: Fri Sep 07, 2012 8:06 am Up
Black and gray should be interchangable.
Green certainly are not as they are quad-jet.
SteveTDCi
PostPosted: Fri Sep 07, 2012 9:18 am Up
Thanks, I took the fuel rail out last night, its about a 20 minute job .... Smile
PostPosted: Fri Sep 07, 2012 9:49 am Up
Golden opertunity to clean the injectors one by one, you'll be amazed.
If you search Yourtube there are a couple of vids showing a simple-ish way of doing it yourself
with makeshift tools and carb-cleaner spray. If you do use carb-cleaner, wear gloves at all costs. Smile
