Posted: Sat Sep 08, 2012 12:32 pm |
Ok so I've changed cams, lifters, oil change and flush but still nothing changes anyone got any ideas? Its driving me crazy and every garage up here says that they ain't willing to delve into taking apart an engine?! I've had mechanic mates look at it and they all say its defo the lifters but they were changed and still the identical noise. Could it be anything else? What's this fuel rail tapping I keep reading about? Could it be this? Arrgh!!
| 2005 Peugeot 206 Gti 180, Silver, 38,000mls  | |
Posted: Sat Sep 08, 2012 12:35 pm |
Had the belts done?
Timing could be out?
Posted: Sat Sep 08, 2012 12:40 pm |
yup. New belt. Its a replacement engine and had new belt put on when I put it in. Been running fine for 2 months and outta the blue the tapping starts.
Posted: Sat Sep 08, 2012 12:51 pm |
Had the belt checked since?
Could be loose or something.
idk other than that mate sounds a b*****d though!
Posted: Sat Sep 08, 2012 12:57 pm |
Belt was checked today when cams and lifters were changed. What else in the he'd could make that noise? Do you know about the tapping fuel rail thing I keep reading on the net?
Posted: Sat Sep 08, 2012 2:39 pm |
Exhaust rattle ?
or does it tap faster when you rev
Posted: Sat Sep 08, 2012 2:59 pm |
what cam and lifters did you use?
brand new? used? oem? cheap pattern?
Posted: Sat Sep 08, 2012 3:13 pm |
Taps faster when rev'd. They are oem cams I took outta my last engine but cams were ok. Not scored or anything.
Posted: Sat Sep 08, 2012 3:21 pm |
what lifters did you use then?
old stuff?
did you mixed up with the order?
Posted: Sat Sep 08, 2012 5:36 pm |
Lifters I had refurbed professionally. What else apart from lifters and cams could it be?
Posted: Sat Sep 08, 2012 5:38 pm |
hold on... What order?
Posted: Sun Sep 09, 2012 11:05 am |
PugGti180 wrote: |
hold on... What order? |
if you got new lifers then there is no order.
however if you use 2nd hand lifers your suppose to use the corresponding camshaft as well and not to swap the order of the lifters. (as lifers and camshaft lends to wear out differently at different position)
what oil did you use?
Posted: Mon Sep 10, 2012 3:52 am |
Did you change your oil pump ?
| 2005 206 RC RED
Lot's of CNC machined customs pars.  | |
Posted: Mon Sep 10, 2012 7:11 am |
Sticky Valve perhaps??
Posted: Mon Sep 10, 2012 1:43 pm |
Castrol magnatec. Oil pump is fine as oil is reaching the head fine. A sticky valve? Tell me more..
