Latest: Kifi69
Overall: 17183
Online Now [971]:
Visitors: 970
Today: 103751
Total: 144731763
Forums › The Car › 206 Problems › weird clunk!
weird clunk!
nathdavies91
PostPosted: Tue Sep 11, 2012 3:49 pm Up
ive got a weird rattling noise followed by a clunk comeing from the rear of my 180 gti, its had new shocks, ive taken the lateral bars off and driven it its still the same, and there's no play in the wheels any way atall and its not the exhaust! anyone had this problem? i need help as its driving me crazy! making me want to get rid Sad
chuckstar34
PostPosted: Tue Sep 11, 2012 4:17 pm Up
Loose Spare ????
Chuckster.
NathanG
When does it happen. Does it only happen going around bends or does it only really happen when you go over a speed bump or something like uneven ground.
nathdavies91
PostPosted: Tue Sep 11, 2012 4:20 pm Up
180s dont have a spare lol, yee its whenever its uneven ground or if i go over bumps. recon it could be the trailing arm bearings?
NathanG
PostPosted: Tue Sep 11, 2012 4:21 pm Up
Have you changed the rear dampers.
chuckstar34
PostPosted: Tue Sep 11, 2012 4:22 pm Up
Actually I did have a punter who had a similar sound, and I found it to be the Hand brake cables slapping the tub over bumps. Clip and broken of the fuel tank and it was just floating around.
Chuckster.
NathanG
PostPosted: Tue Sep 11, 2012 4:24 pm Up
I had a problem with the rear damper on the passenger side. It just constantly knocked. That happened when i adjusted my torsion bars and fitted brand new Blisten shocks.
chuckstar34
Shows how many 180's ive come across lol
Chuckster.
NathanG
PostPosted: Tue Sep 11, 2012 4:29 pm Up
jack the rear of the car up so both wheels are off the floor (get some axle stands involved). Lift your wheels up and down and have a look at where the sound is coming from. I dont think it'll be the trailing arm bearings.
nathdavies91
PostPosted: Tue Sep 11, 2012 4:33 pm Up
yeah ive put new dampers onit yano! recon it would be worth puttin the old ones back on to see if the noise goes atall? i cant remember if it did it before or not! its really p**sing me off tho! i have jacked it up on axle stands and i still cant figure out were the noise is coming from! most annoying problem ive come across! i did attempt lowering the torsion bar with no luck before bt im sure it clunked before that!
NathanG
PostPosted: Tue Sep 11, 2012 4:36 pm Up
£10 says its the rear dampers. Slap the old ones back on. Do it 1 at a time so you can find the offending item and return your new one from whence it came and demand a different one. Thats what i did and their both mint now. Result.
nathdavies91
PostPosted: Tue Sep 11, 2012 4:40 pm Up
ill give that a go tomorrow and ill update Smile
NathanG
PostPosted: Tue Sep 11, 2012 4:41 pm Up
Result. Update is always worth it, may help someone else down the line.
nathdavies91
PostPosted: Wed Sep 12, 2012 2:34 pm Up
ive changed the shocks over today............. its still the same! bt as it was jacked up on stands i lifted the wheels up and weirdly the drivers side was alot easyer to move than the passenger side! and there seemed to be a clunk coming from the torsion bar some how! any ideas anyone?
PostPosted: Wed Sep 12, 2012 3:55 pm Up
Is it lowered by any chance? Sounds like the bearings have gone.
