Posted: Fri Apr 06, 2012 8:38 am |
bonnet insulation to keep or not to keep is the question??
does it actually make any difference if you take it off just as mine is sagging a bit in the middle and rubbing on my nice carbon engine cover
so just wandering if any of you guys have taken yours off??
thank Rich
Posted: Fri Apr 06, 2012 8:41 am |
Took mine out when the induction was fitted to add to the RAWR a little, day to day didn't actually notice it was gone!
Posted: Fri Apr 06, 2012 8:54 am |
Mines off due to it rubbing on bits in the bay and looking a bit tatty.
Posted: Fri Apr 06, 2012 8:57 am |
its only there to reduce noise, i don't think it has any other purpose, i have mine out right now due to a repaint I'm in the process of, but will put mine back to save the neighbours when i come home at all hours
Posted: Fri Apr 06, 2012 9:05 am |
It also helps protect the bonnet from the engine heat ...
Posted: Fri Apr 06, 2012 9:06 am |
i removed mine as soon as i bought my 206, prefer to see the nicely painted underside of a bonnet then some horrible material
Posted: Fri Apr 06, 2012 9:24 am |
I actually retrofitted it to my TU3 206, reduces noise a little bit & also stops the injectors getting damaged when the washer jets leak water
Posted: Fri Apr 06, 2012 9:39 am |
Lol if you haven't seen my set up you'd know I'm not to fussed about the noise yer it's just rubbing on my c/f engine cover and don't want it to rub the laquer off
Posted: Fri Apr 06, 2012 9:44 am |
Bin it
Posted: Fri Apr 06, 2012 10:33 am |
buy a new nice looking one ?
Posted: Fri Apr 06, 2012 10:55 am |
| gazza82 wrote: |
| It also helps protect the bonnet from the engine heat ... |
Did 300 miles in a motorway journey averaging 100 mph through Germany and the washer jet tubes weren't even soft... (checked because i was paranoid it would melt) maybe in summer it protects against heat?
Posted: Fri Apr 06, 2012 11:16 am |
put it this way , if it did nothing peugeot wouldn't waste money putting it on
Posted: Fri Apr 06, 2012 12:20 pm |
Mine never had one :S mind you mine was built in France so they probably skimped on everything they could knowing it was going to the British market!
What is it, like felt stuff?
Posted: Mon Sep 17, 2012 5:58 am |
It is for protection from the heat. Just install it properly. A charity that makes winter jackets for the homeless recently received a substantial gift from General Motors. The company donated excess car insulation, which makes the coat lining. I have to buy a car that works well for me.
Posted: Mon Sep 17, 2012 7:23 am |
never even had one
