Latest: tbafonso
Overall: 17130
Online Now [90]:
Visitors: 89
Today: 9735
Total: 103832071
Forums › The Car › 206 Problems › 206sw 1.4hdi, air bubbles in fuel pipe non start
shellysexbomb
PostPosted: Thu Sep 20, 2012 3:46 am Up
Hiya Very Happy
Got pug 206 sw 1.4 hdi and just had the turbo replaced, only done 43000 Shocked
Now it's been starting and cutting out. Air bubbles in fuel line next to primer. Been managing to get it to run (it goes fine once its going) but today it has given up the ghost. Stop light is now flashing too (cant recall if it does this before starting) Battery is almost dead through trying. How much am I looking at paying for diagnostics? i read a thread on here about a pipe wearing through under the air filter so am going to ask green flag to check that for me :o)) Any other ideas?
richpowell91
PostPosted: Thu Sep 20, 2012 4:04 am Up
Would put good money on it being the pipes under the airbox, getting more of these at work. I think the pipes are about £60 from Peugeot
shellysexbomb
PostPosted: Thu Sep 20, 2012 4:24 am Up
Thanks Rich, am hoping its this rather than fuel pump or injectors or something :oS
Will let you know if you were right as soon as I find out :o)
www.scaregrounds.co.uk
richpowell91
PostPosted: Thu Sep 20, 2012 5:44 am Up
Have you pumped the hand primer untill it goes hard and tried starting it? That should force enough air put for it too start.
shellysexbomb
PostPosted: Thu Sep 20, 2012 6:33 am Up
Been doing that all week (hoping to get to my first day off so it can go to garage) Unfortunately it wouldn't play ball this morning. Went out after and hour and it has started, so its now in the garage. Fault codes p1113 and 00087........:oS
richpowell91
PostPosted: Thu Sep 20, 2012 6:40 am Up
Both codes relate to fuel pressure being low due to air being in the system and cranking I would say so nothing to worry about.
shellysexbomb
PostPosted: Thu Sep 20, 2012 6:43 am Up
I hate the waiting around for the garage to ring. Its a bit of a trust issue sometimes as well as most garages assume us ladies know nothing. Ah well, valium anyone? :oD
shellysexbomb
PostPosted: Thu Sep 20, 2012 10:14 am Up
All the pipes are apparently ok, garage think fuel filter maybe at fault (its never been changed to my knowledge so he could have a point) He's fitting new fuel filter and then its panic stations as other options may be a tad more expensive :oS
shellysexbomb
PostPosted: Fri Sep 21, 2012 3:23 am Up
Had air filter and fuel filter changed (£80) and fingers crossed it seems to be ok now. Would the fuel filter have caused? Was thinking maybe if seals were gone on it, it might have allowed air to be sucked in?
shellysexbomb
PostPosted: Fri Sep 21, 2012 9:17 am Up
Just gone out and had it start, then cut out again straight away so the problem goes on :o(
shellysexbomb
PostPosted: Mon Sep 24, 2012 11:04 am Up
Car has been back in garage since Saturday. Mechanic is ADAMANT there are no leaks in pipes and the car has behaved herself for him. Intermittent problem then. HOW????? Any ideas anyone?
PostPosted: Mon Sep 24, 2012 1:43 pm Up
I would put money on air in the lines, but you might have a problem tracing where its coming from. You'll just have to trace the fuel lines.
04palmerh
PostPosted: Tue Sep 25, 2012 3:42 pm Up
i had the same problem with mine, i replaced mine with rubber lines, but kept the attachments on the ends. primed it till no air was going through and it started fine, mines done 170,000 and i knew the previous owner, the fuel filter hasnt been changed since 100,000. so they last quite a while
shellysexbomb
PostPosted: Wed Sep 26, 2012 12:32 pm Up
Have jsut had the air filter housing off and checked the pipes myself There is indeed a hole in one of them. I have taped it as a temporary fix and will get them replaced asap. Hopefully this is the ONLY thing letting air in and I will be back to my reliable beastie :o)
shellysexbomb
PostPosted: Wed Sep 26, 2012 12:34 pm Up
What is really annoying about this is I TOLD my mechanic to check this FIRST. He claims he did. Guess I wont be using him any more :oS
