Latest: S2cgm
Overall: 17178
Online Now [1174]:
Visitors: 1173
Today: 61514
Total: 137490848
Forums › The Car › 206 Problems › ESP problem please help now sorted
Danielpates
PostPosted: Thu Sep 20, 2012 3:52 pm Up
have got an error come up on my display saying asr/esp not functioning or something along them linesc
have baught an obd 2 reader off ebay to read the fault codes and itt doesnt work
could some one tell me why this is
thanks for looking
PostPosted: Thu Sep 20, 2012 3:55 pm Up
Did you have ignition on? Might be no good if its a cheap one.
Does your ABS light come on?
Danielpates
PostPosted: Thu Sep 20, 2012 4:13 pm Up
yes mate had ignition on and tried it when it was off to
no the abs light isnt on its jus the esp light but have tried pressing the button ofn and off but still no difference
PostPosted: Thu Sep 20, 2012 4:27 pm Up
generic readers won't read those codes. You need peugeot planet/diagbox
most cheap ebay code reader can only read p-code; so that will not work in your case
HDI90
PostPosted: Thu Sep 20, 2012 4:39 pm Up
Launch CReader will work with abs and esp faults
GTI 180
Danielpates
PostPosted: Thu Sep 20, 2012 4:54 pm Up
ok thanks guys will have to take it to a garage then and have it plugged in instead of doing it myself
Danielpates
PostPosted: Fri Sep 21, 2012 10:05 am Up
have just had the codes red and the codes were v1105 absence of communication with the steering wheel angle sensor no signal and v1305 operation steering wheel angle sensor
PostPosted: Fri Sep 21, 2012 10:10 am Up
You have done the obvious & checked for blown fuses for the ESP system?
Sounds like it's new com 2000 time Laughing
Euro Car parts will do you a new Valeo com 2000 pretty cheap, well cheaper then Peugeot main dealer.
ESP steering angle sensor is built in to the com unit.
206 with ESP is pretty rare & the com 2000 units are silly money new from Peugeot.
Danielpates
PostPosted: Fri Sep 21, 2012 10:43 am Up
Tbh mate haven't got a clue what fuse to check.whats com 2000
PostPosted: Fri Sep 21, 2012 10:49 am Up
The complete digital stalk unit behind the steering wheel.
Danielpates
PostPosted: Fri Sep 21, 2012 10:54 am Up
What fuse do I check for the ESP then
Danielpates
PostPosted: Fri Sep 21, 2012 4:35 pm Up
Bump
Danielpates
PostPosted: Sat Sep 22, 2012 3:09 am Up
will be checking fuses this morning what fuse do i have to check
PostPosted: Sat Sep 22, 2012 3:35 am Up
Have you tried searching "esp fuse"?
Most of the time when no one answers a question it's because the answer can be found somewhere on the forum just by searching.
