Posted: Sun Sep 23, 2012 8:08 am |
Hi,
I have just bought some QH (Quinton Hazell) brake discs from my local motor factor. I didn't really pay much attention to detail so if the part is incorrect that's my fault! I have put the front brake discs on fine, but the caliper won't fit? It fit the old brake discs. Could this be because these may be rear brake discs they have given me (my rear brakes are drums) or just the incorrect part. I'm also not sure whether my car is 16v or 8v which might also be a problem. I have a 206 1.6 GLX 2000. Anyway I could find this out? And could someone please provide a link to maybe Ebay/another site with correct front brake discs please?
Many thanks!
Posted: Sun Sep 23, 2012 8:12 am |
The discs would be smaller than the old ones if they gave your rear ones. Chances are you've been given discs for another peugeot like a 307, which use the same diameters, but will have the wrong offset causing the disc to sit further in or out than the correct ones. Take them back for a swap, they should be obliging to help you.
Posted: Sun Sep 23, 2012 8:13 am |
Disc must be slightly thicker than the stock disc, you will need new calipers
Posted: Sun Sep 23, 2012 8:17 am |
Thanks for the replies, any ideas on calipers and where I can get these? The brake discs seem correct, on the box it states 206 1.6i?
Posted: Sun Sep 23, 2012 8:20 am |
Did you move the caliper pistons back before removing old discs?
Posted: Sun Sep 23, 2012 8:25 am |
Might be the wrong offset. The gti 138 changed offsets around 2002. Just take them back if there wrong. Are they vented or solid?
Posted: Sun Sep 23, 2012 8:35 am |
check the box to see if there is any parts number on it.
you need 266x20.5 disc
Posted: Sun Sep 23, 2012 8:46 am |
DeadEyePaul wrote: |
Did you move the caliper pistons back before removing old discs? |
This is before I actually put the piston back on. The caliper that holds the brake pads won't fit.
Posted: Sun Sep 23, 2012 8:49 am |
Seabook wrote: |
you need 266x20.5 disc |
Thanks, part number from the box says: BDC3508P
Posted: Sun Sep 23, 2012 9:00 am |
that looks like the right disc to me....
have you got the vin? i can check if you got the correct disc?
and have you got the pics of your brake pad? does it got a round end or square end?
Posted: Sun Sep 23, 2012 9:02 am |
Seabook wrote: |
have you got the vin? i can check if you got the correct disc? |
Yes I'll PM you it, thanks!
Posted: Sun Sep 23, 2012 9:08 am |
yes. you got the wrong disc....
you need 247x20.5 disc.
4246 A7 or 4249 96
Posted: Sun Sep 23, 2012 9:12 am |
that looks right to me
Posted: Sun Sep 23, 2012 9:20 am |
Seabook wrote: |
that looks right to me |
Thanks, won't be using that motor factors again! He actually took a book out, I told him all the info (year, engine size etc.). Although why does it say Peugeot 206 1.6i on the box if it doesn't fit? Is it possible this is for newer models?
