Online Now [495]:
Visitors: 494
Today: 16290
Total: 142829802
Forums › The Car › 206 Problems › Steering Wheel/Horn
Steering Wheel/Horn
GTSX
PostPosted: Sun Sep 09, 2012 12:39 pm Up
I have a problem with the horn not working on my SXi. I did some research on here and tests on the car. It seems the problem is in the steering wheel multiplexed unit.
I tried to take the multiplexed unit off but it doesn't seem to release fully by pushing on the tab. To make things worse I can't get the unit tiireseat properly now either.
Can anyone offer some usefull advice on removing and refitting the multiplexed unit?
GTSX
PostPosted: Wed Sep 12, 2012 3:29 am Up
Ok air bag unit now off. It's not quite the same mechanism as on a Renault for removing it which threw me a bit.
The good news is the horn relay is now clicking but still no horn.
Bad news:
No power at fuses 9, 10, 11 and 12 in the fuse box. Is one of these for the horn (no hand book with the car)?
Can someone send me a photo of where the horn connector block mounts on the airbag unit as it was just laying there when I removed it a it's preventing me from refitting the airbag unit correctly now.
Also can someone tell me which wires from the fuse box go down to the horn?
GTSX
PostPosted: Wed Sep 12, 2012 3:30 am Up
Bad news:
Can someone send me a photo of where the horn connector block mounts on the airbag unit as it was just laying there when I removed it a it's preventing me from refitting the airbag unit correctly now?
GTSX
PostPosted: Sun Sep 16, 2012 4:58 am Up
GTSX
PostPosted: Mon Sep 17, 2012 2:22 am Up
Well a big thanks for your help!
138 views and no one can even tell me what fuse 9, 10, 11 and 12 are for!
Sad Rolling Eyes
myke
PostPosted: Mon Sep 17, 2012 3:01 am Up
Can't help with the problem but with RE: to fuses...
The beginner's guide to a 206 has the fuse listings in.
206info.co.uk/Forums/v...20541.html
Inside there is a link to:
Pre-plexed fuse list:
www.206info.co.uk/Foru...t=107.html
Multiplexed fuse list:
www.206info.co.uk/Foru...t=108.html
Hope that (slightly) helps. Smile
GTSX
PostPosted: Tue Sep 18, 2012 1:30 am Up
Myke, thank you very much.
GTSX
PostPosted: Mon Sep 24, 2012 4:03 am Up
Horn works Very Happy
2 days horn stops Sad
I now have power at the fuse but seamingly no power at the horn unit/steering wheel. I can't hear the realy clicking as before.
Help please MOT imminent
