Latest: tbafonso
Overall: 17130
Online Now [259]:
Visitors: 258
Today: 17385
Total: 103985318
Forums › The Car › 206 Problems › Coolant overheated after car wash
karimali831
PostPosted: Sat Oct 06, 2012 6:45 am Up
So I have only just had a car wash, waiting outside I noticed steam from the engine thinking it was from the pressure hose, noticeably got worse looked inside and the coolant temp was on red limit! Now I am waiting for the AA im worried the engine won't start...?? Sad it probably was on the red for a good few minutes until steam starting forming. Could anything be damaged? There is a puddle ontop the engine
206 GTI 180
PostPosted: Sat Oct 06, 2012 7:47 am Up
why you leave your engine idle anyway? straightly speaking 5-10 mins idle without fan on shouldn't cause overheat.
karimali831
PostPosted: Sat Oct 06, 2012 8:04 am Up
Hmm it still is overheating, aircon is not giving cool air and the fan won't turn.
Checking the fan relays.
206 GTI 180
PostPosted: Sat Oct 06, 2012 8:09 am Up
Check your coolant.
PostPosted: Sat Oct 06, 2012 8:12 am Up
i didn't got radiator fan and i never overheat to redline.
karimali831
PostPosted: Sat Oct 06, 2012 8:15 am Up
There is a lot of corrosion on the fan relays and wiring, maybe enough water got in there to stop the unit working. There are two relays, anyone know if one is aircon?
206 GTI 180
karimali831
PostPosted: Sat Oct 06, 2012 8:41 am Up
After checking the relays:
desmond.imageshack.us/...es=landing
Looks like I must also get a new fan wiring harness as the sockets and wiring look corroded. Anyone know the part names please?
206 GTI 180
PostPosted: Sat Oct 06, 2012 8:48 am Up
the relay is 6547 TX
PostPosted: Sat Oct 06, 2012 8:51 am Up
Those relays should clean up easily enough if your careful, just dont snap any of the terminals of Laughing
PostPosted: Sat Oct 06, 2012 8:53 am Up
i always wonder if they are just normal 5 pin relay? Laughing
PostPosted: Sat Oct 06, 2012 9:04 am Up
I've got some stashed away somewhere in my stock of Peugeot parts, if I ever get bored one day ill take one apart Laughing
The pin out on the terminals will show if its just a normal 5 pin relay.
karimali831
PostPosted: Sat Oct 06, 2012 9:07 am Up
Can I get in halfords? Need to fix today, uni etc. I can drive but in traffic is no good. Age problem, wish I thought of it before
206 GTI 180
PostPosted: Sat Oct 06, 2012 10:16 am Up
Yes they are, and no protection diodes on the coil either. (plain SPDT 12V)
Trouble if you clean them is because the top nickel-plating is gone, the copper will just oxidize green again in
no-time. I always bin those triumphantly and use silicon grease spray for future protection on the contacts.
PostPosted: Sat Oct 06, 2012 10:56 am Up
The wiring terminals will be corroded too and might have even corroded right through enough to break the wires.
Ideally it needs the bumper taking off and a thorough clean up /repair making.
karimali831
PostPosted: Sat Oct 06, 2012 12:00 pm Up
When you turn air con on you hear "click" noise, if this is from the relay then relays are OKAY?
206 GTI 180
