Latest: Kifi69
Overall: 17183
Online Now [530]:
Visitors: 529
Today: 73750
Total: 144701772
Forums › The Car › 206 Problems › squeaky exhaust
squeaky exhaust
broookesy
PostPosted: Sat Sep 29, 2012 3:41 pm Up
I have just had a whole new exhaust system fitted for my 1.1 206. everytime I take it to the garage they fix the problem but it seems to come back within a week. The problem is very loud whilst the car is warming up and squeaks everytime i tap the revs change gear, use clutch. The problem goes after the first couple of miles once the car is up to temp.
anyone any ideas many thanks!!
206 1.1
Custom BootBuild
PostPosted: Sat Sep 29, 2012 5:37 pm Up
Turn the radio up until the cars warm.
Get the car up on ramps, crawl underneath and move the exhaust gently to see if it's squeaking on the mounting rubbers. A bit of red grease will solve it if it is.
Possibly the engine mounting though. With engine turned off, gently rock the engine to see if you can identify where the squeak is. Might need 2 of you, one with their head in the engine bay, the other led underneath.
When you have found the squeak, take it from there for repairs or replacing parts.
frenchfrog40
PostPosted: Sun Sep 30, 2012 2:56 am Up
mine has this and we jacked it up yesterday to have a look. seems so be squeaking from the join to the manifold. tried tightening and loosening the screws and it made a difference but we couldnt get it to go away so im taking mine back to the place that put it on to see if they can fix it.
Iv had:
Razor34
PostPosted: Sun Sep 30, 2012 3:29 am Up
I had the same problem, it turned out the exhaust centre had fitted the wrong exhaust clamp at the front joint. Replaced and problem solved.
Bet it turns out to be this Smile
Ray
broookesy
PostPosted: Sun Sep 30, 2012 8:30 am Up
sweet thanks for that info guys al be popping to see him and get the problem sorted! if it occurs i can just take it to exhaust UK surely they will fix the problem!
206 1.1
Custom BootBuild
PostPosted: Sun Sep 30, 2012 8:38 am Up
None of the above.
The centre pipe join to the cat pipe has a pair of springs to provide coupling between the two.
If the two springs are not tight-enough (M10 bolts) OR if the sealing ring inside has broken/colapsed
this gives excessive movement and causes exactly this noise when pressing clutch or reving etc.
Check your enginemounts too because they might look 100% perfect but when taken appart, there
can be obvious wear and loss of damping due to the rubber going rock-hard over time.
Razor34
PostPosted: Sun Sep 30, 2012 1:19 pm Up
It is the clamp would put money on it. Nothing to do with engine mounts or springs
Ray
PostPosted: Sun Sep 30, 2012 3:24 pm Up
OK, £10.
The springs are part of the special clamp. Just tighten-up and you're away.
Engine mounts will need checking by the time it's squeaking at that join,
due to increased movement of the engine & gearbox.
party7uk
PostPosted: Mon Oct 01, 2012 2:24 pm Up
there are 2 types of sealing cone washers at the front joint, see if its fitted with the metal wire one , if
it is then change it with a fibre cone. that should cure it.
hello
James_sinovi
PostPosted: Mon Oct 01, 2012 3:54 pm Up
Been over this a few times, as stated above yes it will likely be the flexi joint between the front and centre pipes. See link below:
http://www.206info.co.uk/Forums/viewtopic/t=48269/highlight=exhaust+rattle.html
