Latest: tbafonso
Overall: 17130
Online Now [94]:
Visitors: 93
Today: 21013
Total: 102493269
Forums › The Car › 206 Problems › intermittent battery drain
tonellie
PostPosted: Wed Oct 03, 2012 6:42 am Up
hi i have a strange problem
the car drives with no problem
a couple of weeks ago took the wife shopping
parked then came back and the car battery was flat
got a jump start and no problem till a week ago
then same thing happened got a push fine after that
till this morning went out to start it battery flat again
i think there must be something draining the battery
has anybody had the same problem and how did you fix it
its a 2003 206 1.1 look
battery and alternator ok
thanks in advance
PostPosted: Wed Oct 03, 2012 7:04 am Up
Battery's had it.
iainlovatt
PostPosted: Wed Oct 03, 2012 7:22 am Up
Got for a 30 min drive the. Test the battery and see what volts it comes back. Should be just under 12, if its a lot less than that then u know your problem, if unsure what your doing take it halfords and they will tell u !
(My Garage)
PostPosted: Wed Oct 03, 2012 7:26 am Up
No.
Battery should be at least 12.75V with engine off, and 14.0V engine running.
Even then, you can't be sure it's OK 100%.
PostPosted: Wed Oct 03, 2012 10:08 am Up
Get the battery & charging system tested by someone who knows what there doing & has the correct equipment.
Modern car batterys do just die when they reach the end of there service life, its not like the old days where a battery would give a few months warning its on the way out.
