Latest: lio94
Overall: 17181
Online Now [111]:
Visitors: 110
Today: 51890
Total: 141070180
Forums › The Car › 206 Talk › Boot Swap
Boot Swap
Liam-HuTcH
PostPosted: Tue Feb 22, 2011 8:17 am Up
East Area Rep - Liam-HuTcH
is there a how too any where of how to do this? as it looks fairly simple todo its just the Wiring im a bit confused about, so any help would be much appreciated.
Team: Smashed Up Firedance
Team: Black 206
PostPosted: Tue Feb 22, 2011 8:25 am Up
think you have to disconnect all the wiring inside the boot and pull it out throught the holes at the top Confused dont think there's just a plug like on the doors
apart from that just the struts that pop off and the nuts that hold it on be careful though the tailgates are heavier than you would expect!
Kersh
PostPosted: Tue Feb 22, 2011 9:38 am Up
you have to cut your washer pipe which is pretty gay but you can tape it back together or something
Member number: 36
Danny.
PostPosted: Tue Feb 22, 2011 10:17 am Up
Whys this surely you just take it of the 3rd break light...
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
PostPosted: Tue Feb 22, 2011 10:19 am Up
What He Said
Sounds harder than it is. Did mine on my own in about 30mins iirc
In the boiling hot sun Laughing
Liam-HuTcH
PostPosted: Tue Feb 22, 2011 10:48 am Up
come do mine then ben? Lmao. Wil have a look into it
Team: Black 206
PostPosted: Tue Feb 22, 2011 11:08 am Up
If you get stuck I will yer, **give you a hand Wink **
Liam-HuTcH
PostPosted: Tue Feb 22, 2011 1:22 pm Up
2 fingers on that hand dont count as helping lmao Razz
Team: Black 206
Jamie1337
PostPosted: Tue Feb 22, 2011 1:51 pm Up
Trade Rating: +37
It's fairly simple. You'll need to do the following: Remove passenger side plastic boot panel (with the boot light in). Unplug the boot plug and remove earth cable too. Remove 3rd brake light and remove the washer pipe. Remove 4 10mm nuts holding the boot in place. Then, with help, take off the boot stuts with a small screwdriver as these will ensure the boot doesn't suddenly drop when removing, and will prevent damage to paintwork. Fairly simple, you've just got to cut the drivers side seal slightly (where it stays on the bodywork) in order to remove it though
Light Right Foot FTW!
welsh_ben
PostPosted: Wed Oct 10, 2012 8:31 am Up
How the hell do you remove the bottom part of the boot struts on a convertible anyone know??
hello
welsh_ben
PostPosted: Wed Oct 10, 2012 9:04 am Up
Done it! What a pig that is pretty much taking the entire rear out!
hello
