Latest: ArtistKS
Overall: 17145
Online Now [37]:
Visitors: 36
Today: 1702
Total: 115990223
Forums › The Car › 206 Problems › car wont start possible electric problem help!!
markj
PostPosted: Fri Oct 05, 2012 4:48 am Up
my 206 1.1 was working then when i stopped the car and tried starting it after 5 mins nothing fires up lights come on got a mechanic telling me could be the fuse box but its deffo electrical any help would be appreciated thank in advance.
supreme clean north easts number 1 cleaning company!
PostPosted: Fri Oct 05, 2012 5:55 am Up
refuse to start when hot is very likely to be bad starter motor
markj
PostPosted: Fri Oct 05, 2012 6:11 am Up
makes a buzzing noise comeing from fuse box under bonnet one ?
PostPosted: Fri Oct 05, 2012 6:15 am Up
you could check the relay...
markj
PostPosted: Fri Oct 05, 2012 6:16 am Up
which is where lol ? im not mechanically minded you see. and what am i checking it for ?thanks
DeadEyePaul
PostPosted: Fri Oct 05, 2012 8:30 am Up
To be honest if your not mechanically minded I'd be worried your doing more harm than good. I'd suggest rather than mucking about and buying parts you might not need. VISIT A MECHANIC!
markj
PostPosted: Fri Oct 05, 2012 9:02 am Up
havent bought any parts as of yet had a MECHANIC out he couldnt find a problem through diagnostic there is a buzzing sound comeing from the fuse box under the bonnet if you have any idea on what can cause that ie, water damage to the circuit board damaged wiring? ... as im about to go and get a fuse box just want to make sure im getting the right thing in and its not anything else.
markj
PostPosted: Sun Oct 07, 2012 5:24 am Up
bump!
if i didnt explain it before i'll explain it now, the car wont start at all been told its the electrics as there's no faults with engine (diagnostic testing done) there's a buzzing noise comeing from fuse box when i turn the ignition nothing cranks over batterys charged and works fine starter motor fine everything fine just for some bizzare reason it wont start any ideas or any help would be appreciated thank you
DeadEyePaul
PostPosted: Sun Oct 07, 2012 5:43 am Up
Have you checked the earths? Are they loose? Have you disconnected your battery at some point but not followed correct disconnection procedure? When you said you charged the battery was it still connected to the car? I suspect it's either the earth or you have fried the ecu.
Earth is cheap fix ecu isn't the easiest thing you can do is get Peugeot to plug it into their software as any faults will shout error codes and will pinpoint the error or at least point to the right direction.
If you need a number for a low loader(toe truck) I know someone who charges a good price
