Latest: tbafonso
Overall: 17130
Online Now [331]:
Visitors: 330
Today: 47944
Total: 102784912
Forums › The Car › 206 Problems › Spare key don't work - does it say when battery flat?
crocdino
PostPosted: Fri Oct 05, 2012 1:07 pm Up
Spare key that came with the car does everything but unlock/lock the car.
It unlocks it with the key, alarm rings, put key in ignition the car starts and alarm stops. My main key works fine.
I'm thinking it's the battery but wouldn't it flash up on the display if that's the case?
If not, what battery do i need?
I've tried the re-syncing and it's not worked.
Car is a 53 Multiplex
Cheers.
GTI 138 facelift - Runabout
335d M Sport - Cruiser
PostPosted: Fri Oct 05, 2012 1:11 pm Up
Key needs to have been in use for the BSI to warn of a low keyfob battery.
Open the key & have a look at the battery part number.
crocdino
PostPosted: Fri Oct 05, 2012 1:13 pm Up
Okay cool that makes sense.
I'll do that. Don't suppose it could be any other issue?
crocdino
PostPosted: Fri Oct 05, 2012 1:28 pm Up
If anyone else is reading the battery in mine is CR2016
crocdino
PostPosted: Wed Oct 10, 2012 7:22 am Up
To conclude - new battery fitted and it worked straight away. No re-syncing required.
