Latest: Stu-mill
Overall: 17131
Online Now [112]:
Visitors: 111
Today: 77160
Total: 104762718
Forums › The Car › 206 Problems › Coolant overheated after car wash
Go to page Previous  1, 2
PostPosted: Sat Oct 06, 2012 12:18 pm Up
That's the clutch on the compressor switching on.
anton1989
PostPosted: Sat Oct 06, 2012 3:23 pm Up
Trade Rating: +16
this is what happend to mine, very common
got a second hand one and new relays
karimali831
PostPosted: Sun Oct 07, 2012 10:33 am Up
hopefully the problem is as small as this, you know how I can check it is not the water pump?
206 GTI 180
PostPosted: Sun Oct 07, 2012 10:51 am Up
check the bottom and upper coolant pipe.
if both are warm then water pump is fine
karimali831
PostPosted: Mon Oct 08, 2012 11:50 am Up
I replaced the wiring harness and relays but the fan only comes on at 105c ?? It is always go up to 105 until fan triggers and drops to 98c. Any thoughts? Thanks all for the help!
206 GTI 180
PostPosted: Mon Oct 08, 2012 12:52 pm Up
Lookslike the high speed fan is working but the relay controlling the slow one is crusted up.
karimali831
PostPosted: Mon Oct 08, 2012 12:59 pm Up
I am sure I wired it all correctly, got two new relays also.
I can only think the resistor needs changing, it looks fine, but if the high speed fan works so the resistor must work?
206 GTI 180
PostPosted: Mon Oct 08, 2012 1:09 pm Up
High speed fan doesnt use the resistor. The low speed fan uses the resistor to restrict the current to the fan.
If you remove the resistor and bridge the wiring and the fan spins at high speed you'll know the resistor is faulty.
karimali831
PostPosted: Mon Oct 08, 2012 1:12 pm Up
thanks!
so apart from the resistor, with all wiring and relays and fan working at high speed can it be anything else?
206 GTI 180
Page 2 of 2
