Latest: tbafonso
Overall: 17130
Online Now [179]:
Visitors: 178
Today: 68435
Total: 103735235
Forums › The Car › 206 Talk › Help with centre console, date/time etc
lee1985
PostPosted: Sun Oct 07, 2012 8:04 pm Up
Car is a GTI 180
About a week ago my clock somehow reset itself to 01.01.00 and the time at 0.00. Everything works fine, but obviously have for some reason been reset.
My primary question is how do I set/change the date and time on the actual centre console?
Secondly, does anyone know what might have caused them to 'just reset'. I think I turned the ignition off or something and then turned it back on and it just re-set - I was only sat in the car and didn't do anything dodgy.
Had a new Kenwood radio put in the car if it helps advise how to reset due to it being non standard, but that was this morning.
mattvaretto
PostPosted: Mon Oct 08, 2012 5:00 am Up
Will reset if the battery is disconnected and you have to use the two buttons either side of the display to change it. Hold one in cant remember which side but hold until it flashes then use the other button to change the date/time should tell you in the manual
PostPosted: Mon Oct 08, 2012 5:15 am Up
Owners handbook
As Matt says it resets when you disconnect the battery. May be a dodgy connection behind the MFD, or something was disturbed when the new HU was fitted.
