![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › Bottom Engine Mount |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Mon Jul 08, 2013 6:31 am |
Does the ring around the engine mount come out?
![](http://i1278.photobucket.com/albums/y516/zackpn1989/Untitled_zps08f0a8e6.png~original)
Cheers
| | ![](images/spacer.gif) |
Posted: Mon Jul 08, 2013 6:52 am |
It had to go in! What are you taking it out for?
Posted: Mon Jul 08, 2013 6:57 am |
Its fine a while back up graded my engine mounts just wanted to confirm that ring stays in there ![Smile Smile](images/smiles/icon_smile.gif)
thanks
Posted: Mon Jul 08, 2013 11:20 am |
It comes out.
Posted: Mon Jul 08, 2013 11:22 am |
What the ring a round the rubber mount?
| ![](themes/base/images/forums/otr.gif) |
