Latest: tbafonso
Overall: 17130
Online Now [157]:
Visitors: 156
Today: 2015
Total: 103969968
Forums › The Car › 206 Problems › MOT failure braking issue
shaun88
PostPosted: Mon Oct 08, 2012 11:41 am Up
Hi guys,
i've been playing about with the mechanical side of cars for a few years now and have learnt and fixed quite a lot succesfully, just stuck on this though as unsure what parts to replace,
1 (front to rear) brake pipe excessively corroded 3.6.b.2c
2 rear to (L.A.V) brake pipe excessively corroded 3.6.b.2c
3 (L.A.V to flex) brake pipe excessively corroded 3.6.b.2c
my guess is 1 equals the black copper brake lines running from master cylinder to the rears
think the flex is the flexipipe to the caliper but im unsure what a L.A.V is and also which sides to be looking at
any help would be greatfully received
thanks guys
PostPosted: Mon Oct 08, 2012 12:54 pm Up
LAV is load apportioning valve,
that will be the brake compensation valve which is located on the rear trailing arm
shaun88
PostPosted: Mon Oct 08, 2012 12:58 pm Up
Fantastic, not had chance to have a look yet, would i be right in assuming there are two pipes running underneath car into the "lav" and then from there to the flexes on each side??
PostPosted: Mon Oct 08, 2012 1:00 pm Up
yes. and it looks like this
www.ebay.co.uk/itm/PEU...4cef414bcf
shaun88
PostPosted: Mon Oct 08, 2012 1:07 pm Up
Again many many thanks, i love forums.....
one last question is there only one of these and is it located offside nearside or somewhat in the middle on a 99 1.1 petrol 206
regards
shaun
PostPosted: Mon Oct 08, 2012 1:09 pm Up
can't remember which side but you should be able to see it through rear wheel, it's normally cable tie to the trailing arm.
shaun88
PostPosted: Mon Oct 08, 2012 1:19 pm Up
Just so im looking at changing the right pipes,
L.A.V to flex = two pipes to o/s and n/s flex pipes from the lav
Front to Rear = two pipes from master cylinder to the rear??
this is the confusing part
rear (to L.A.V)??? do the pipes join again underneth the car or is it a straight run from master to lav
im going to change all rear pipes from master cylinder all the way through to the flex joints, does this sound right or am i missing something that would be visible when underneath the car??. sorry to be a pain but one thing i have never dealt with is replacing brake pipes, getting them on and off i can do but having them made at a local motor factors.
thanks all for your time and patience,
regards
shaun
Very Happy
PostPosted: Mon Oct 08, 2012 1:27 pm Up
i think once you have a look underneath you should be able to spot the problems.
the rear brakeline is like this:
2 copper pipe from the MC to the brake compensator; then copper pipe->flex pipe->copper pipe (calipers/drum) on each side
shaun88
PostPosted: Mon Oct 08, 2012 1:30 pm Up
thanks for that i shall have a look in the morning, just confused with all the rears etc lol, thanks for the advice though
regards
shaun
