Posted: Wed Oct 10, 2012 6:37 am |
Okay here goes…
Just as well I didn’t make a bet with you BSI.
I apologise for ignoring all advice I was given and went ahead and bought the car.
It seems people can make themselves look incredibly retarded when selling a car to the point when you believe them when they say they have no idea about cars! Unfortunately this retard was very smart as the diesel filter message didn’t come up on the test drive. It did however this morning when I filled up!
Peugeot want £300 for regen which may not work a further £850 for a complete replacement.
I have had quotes for removing the whole thing, one for £380 but that's in Manchester and another for £450 in Chelmsford, 18 miles from me.
I would have had to replace/remove it eventually as Pug said that these fail at around 80k so it would have been inevitable anyway.
I would just want a construction answer to, is there any disadvantage of having it removed?
Kind regards,
Alex
Posted: Wed Oct 10, 2012 6:45 am |
I found this, not sure how much help it'll be to you-
' The 'diesel filter' on your cars alarm message is a particle filter in your cars exhaust system that traps most of the diesel particles. The fluid is Eolys fluid that is automatically injected into the fuel each time you fill up.
The fluid helps the particles to burn more readily at a lower temperature.
The particle filter is meant to be changed or cleaned out at 50,000, or on later model cars 80,000 miles. The Eolys fluid is filled up at the same time so that the system works for another 50 or 80k miles.
Most garages will just change the filter which is where the £749 cost is coming from.
If you are handy you can remove the particle filter & clean it yourself with jetted water & fill the Eolys container, costs about £120 for 5l of Eolys.
Your car may just need a good run ie 20 miles up the motorway at 3000 revs & 70 mph which may clean out the filter. But if your car is one that needed the filter service at 50k it will only be a temporary fix.
Do a forum search on 'FAP' & 'Eolys' & you will get a good understanding of how the system functions'.
Posted: Wed Oct 10, 2012 6:47 am |
So the 8 weeks I said on your other thread was more then a bit generous of me, its not even lasted 8 days
Posted: Wed Oct 10, 2012 6:48 am |
Yeah I read that this morning thanks mate. A good run in 4th for 32 miles this morning did not clear it.
Posted: Wed Oct 10, 2012 7:12 am |
Trade Rating: +59
206HdiGti wrote: |
Yeah I read that this morning thanks mate. A good run in 4th for 32 miles this morning did not clear it. |
No wonder. Wouldn't listen to the advice of anyone who hasn't actually owned a DV6.
You'll have blocked the filter more. To attempt a regeneration, you need to drive in a high gear and at low revs, above 40mph.
Get the codes read before you make your next move.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Wed Oct 10, 2012 7:24 am |
Absolutely brilliant!!
Quoted from your previous thread.
206HdiGti wrote: |
I won't be posting them [problems] on here anyway mainly due to the fact I know if I did there would be a hostile reception and I wouldn't get any help. |
| Project Low and Slow.. Going Euro for 2013. Keep your eyes peeled, big plans ahead..
See my project here. | |
Posted: Wed Oct 10, 2012 7:32 am |
MrBSI wrote: |
So the 8 weeks I said on your other thread was more then a bit generous of me, its not even lasted 8 days  |
It obviously had a problem before I bought it.
Everyone makes decisions against people's advice every once in a while i'm sure everyone on here has done it, but you don't learn from mistakes until you make one.
As no one else has answered my question, perhaps you could shed light on if I remove it is there any disadvantage?
ARRAN wrote: |
206HdiGti wrote: |
You have just proved that to be correct by not giving any help or a constructive answer to the question.
Posted: Wed Oct 10, 2012 7:34 am |
Ghosty on here removed his DPF. He had some problems with it, not sure if its fixed now or not.
Posted: Wed Oct 10, 2012 7:35 am |
Lecktorious wrote: |
206HdiGti wrote: |
Get the codes read before you make your next move. |
Thanks mate - how do I get the codes read?
Posted: Wed Oct 10, 2012 8:07 am |
Take it to a Peugeot dealer.
Posted: Wed Oct 10, 2012 8:14 am |
I'm going to see if it goes away when I drive as says above and not ragging it.
Posted: Wed Oct 10, 2012 8:18 am |
Big_Rich180 wrote: |
Take it to a Peugeot dealer. |
Posted: Wed Oct 10, 2012 8:25 am |
It's a bit of an issue as i'm not really in a situation where I can do so until after the weekend.
I'm currently working my final 2 weeks notice since handing in my resignation letter and Company have been A-holes generally and leaving work early is not going to be possible. Going to a two day Indian wedding at weekend too.
I'll see if I can take it on Monday and if it's tom-tucked I'll get it removed on Tuesday.
