Latest: Kifi69
Overall: 17183
Online Now [447]:
Visitors: 446
Today: 100911
Total: 144392444
Forums › The Car › 206 Problems › random rev up on its own
Sim
PostPosted: Wed Oct 10, 2012 11:09 am Up
Hello all,
Last empty tank I fuel up with Tesco's diesel (normally fuel up at ASDA's), and soon after noticed that the car's torque went down. Do they really have worse diesel there at Tesco's ?
Last week I had holiday, the car was parked unused.
When back, checked for any leaks - there was an oil on the ground of about a square inch, and engine mount looked oily (the black-from-oil rounded thing at the slightly lower-right of the picture):
When I restarted driving the car, now it feels as if it gets extra 20 horses at certain revs/gears intermittently. Feeling in 2nd and 3rd that it torques for a couple of seconds with accelerator pedal kept unchanged.
I read about engine mounts being loose -- www.306gti6.com/forum/...p?id=85936 and to tell you more, I crashed into another car 6 weeks ago @ 15MPH -- only front was bent, radiator dislocated, now fixed, engine looked stable, no leaks.
What do you think could be the reason? Where should I look first? And is it critical you think (I should contact my mechanic without too much of DIYing,, my fav part is the latter though :))
Cheers!
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
chuckstar34
PostPosted: Wed Oct 10, 2012 5:11 pm Up
Is there much smoke from exhaust when it happens?? Sounds like the turbo giving up and sucking oil into the combustion system.
Chuckster.
dan_manu
PostPosted: Wed Oct 10, 2012 5:14 pm Up
could it be something as simple as the thermo sensor causing it too rev? just wondering
chuckstar34
PostPosted: Wed Oct 10, 2012 5:18 pm Up
I know on some petrol models there an issue with the throttle sensor playing up and doing exactly this problem. It miss reads the throttle postions and chucks fuel in.
Chuckster.
Sim
PostPosted: Thu Oct 11, 2012 3:43 am Up
Ok, I will check those bits, thank you!
Also I got confirmed from yet another person that ASDA's diesel is way more combustible and the car can actually perform for what its worth.
No more fuelling diesel at Tesco's...
Will fuel up at ASDA's next week, and will tell you the difference (I hope the whole problem is just in the fuel)
We'll wait and see
EV (roadtripper)
GTC VXR (sold)
Gavin28
PostPosted: Thu Oct 11, 2012 4:08 am Up
My old ford mondeo diesel used to hate texaco and morrisons fuel (lower mpg and not as responsive) but ran well on shell. Will be interesting to see if you find a difference too. Never tried asda or tesco fuel myself.
Gav
